Battery keeps shorting out
Old Sep 19, 2023 | 09:50 AM
jeffs109's Avatar
jeffs109
1st Gear
Default Battery keeps shorting out
3 times in 6 months of driving my 76 I have shorted out/blown the battery. Always after a start and very short move...like 30 feet or less; when car is turned off and restarted later, the battery is dead and won't hold a charge. Very frustrating. Any ideas?
Old Sep 19, 2023 | 12:29 PM
MelWff's Avatar
MelWff
You cannt rapidly discharge a fully charged battery without melting something. What determines the dead battery won't hold a charge, a load test? Have you done a parasitic drain test? You could have a partially discharged battery that will start the car only once and then be dead.
Old Sep 19, 2023 | 01:54 PM
motogotro's Avatar
motogotro
My 81 was like that when I first got it and it turned out to be a bad connection at the wire that comes from the positive battery post to the junction terminal by the battery. That wire feeds the entire car and it would lose connection but a jump would seem to fix it for a while.
Old Sep 19, 2023 | 08:12 PM
HeadsU.P.'s Avatar
HeadsU.P.
POS battery cable runs inside the driveshaft tunnel.
Did the cable drop down and rubbing the shaft?
Old Sep 19, 2023 | 09:36 PM
Bikespace's Avatar
Bikespace
Instead of buying more batteries, get a battery disconnect. One that screws together is only $10- or so.
We can only guess, unless you have the ability to do a parasitic draw test. The issue could even be a bad diode in the alternator.
Old Sep 20, 2023 | 12:03 AM
OldCarBum's Avatar
OldCarBum
I would find the issue before connecting another battery into the electrical system.
This sounds like a fire waiting to happen.
Old Sep 20, 2023 | 05:08 PM
Prysmian46's Avatar
Prysmian46
Default Battery losin charge
Get a trickle charger/battery maintainer to keep the battery charged when not driving the vehicle. They can run about 30 to 40 bucks. I have one on my 82 CE.
Old Sep 20, 2023 | 07:39 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
idea? yeah.
find the short before serious things happen.
like fire, battery exploding, wires melted taking equipment with them.
Old Sep 20, 2023 | 07:44 PM
Bikespace's Avatar
Bikespace
Just how fast is it discharging?
To Battery keeps shorting out
