Rag Joint Comparisons
Old Sep 22, 2023 | 01:06 PM
c66vet's Avatar
c66vet
Default Rag Joint Comparisons
Inquiring to find out if anyone has compared available rag joints. The rag joint on my Borgeson has split and must be replaced. I can go back with the Borgeson replacement rag joint (Pn 000941), but will I have to replace it again after 2279 miles. I want to see if I can use another manufactures rag on my Borgeson part. I was looking at other rag joint kits offered by Corvette Central, ZIP, and Doorman. I'm leaning towards the ZIP (SC-778) kit, but wondering if the rag joint matches up to the Borgeson rag joint, rag diameter, hole spacing, and ID of the 4 holes in the rag. Thanks
Old Sep 22, 2023 | 07:35 PM
Tampa Jerry's Avatar
Tampa Jerry
There was a post recently about replacing the rag joint with a universal joint and a carrier. Search the C-2 and C-3 forums. Jerry
Old Sep 22, 2023 | 08:03 PM
DC3's Avatar
DC3
The issue with the Borgeson rag joint is that they failed to use proper shoulder bolts and failed to use those odd shaped load spreading washers to prevent distortion of the rubber disc. See this thread I started for more info: https://www.corvetteforum.com/forums...rag-joint.html
DC
To Rag Joint Comparisons
