Next thing to check: lost my spark...
I replaced the points, condenser, coil, plugs,wires
I did this with the distro OUT of the car.
With engine at TDC, I replaced distro, so that the rotor pointed toward #1 plug wire.
Wouldn't start, just cranked.
I took out #1 plug & laid it on engine ground, and saw no spark whilst cranking...
I measured 12VDC on coil + terminal
I also tried replacing original coil, but no help there either.
I made doubly sure the coil wire is making contact.
Any guesses?
Would points do this?
even if things were really out as far as distro position/timing, shouldn't I still see spark?
Is there another test I can try before I put all the old components back in?
Rich
Any guesses?
Rich
How did you determine you were at cylinder 1 TDC and not cylinder 6 TDC?
Do you have a dwell meter?
Why did you remove the distributor?
You have the wire from the distributor connected to the negative post of the coil?
I used a TDC finding tool(inserted into #1 plug hole, rotate both ways.. mark the center
have rather old one, but it's not yet been used/tested(got off ebay)
I guess I figured I'd struggle to change the parts otherwise, but maybe that wasn't necessary: it's my 1st points/condenser swap
You have the wire from the distributor connected to the negative post of the coil? Yes, I do
thanks for helping!
Rich
thanks for helping!
Rich
Dr. Detroit
Received 3,902 Likes
Is the point contact closing when the distributor is turning? It needs to close completely.
Jebby
Jebby
You said there was no spark at the #1 plug wire. did you check for spark from the coil wire? double check your points adjustment.
Pat
Pat
I think my next step is to look at dwell(which I didn't set)
I'll also look into spark from the coil wire..
I just hold the end of it on my tongue, right?
;0
j/k
Try running a jumper wire from the base of the points (not where the coil wire connects but on the base of the points) to an engine ground and then check for spark at the coil wire, this is with the Dist. cap removed and engine cranking. And point gap needs to be ~0.020" on the high spot of the dist. lobe/cam. Let us know what you find.
ok, I connected my original coil wire, and I can see spark jumping from the end, to engine block.
Question: I am seeing spark between the disto body & engine if I lift the disto up from it's
housing.... I believe with key on(not cranking)
Is there supposed to be voltage on the disto body(shaft/gear)??
I thought , "do I have wiring backwards somewhere??"
The black wire coming from the points is going to (-) on the coil. (negative)
are you trying to start with distributor not bolted down?
hook up the dwell metter and set to 30
Can you post a picture of the two wires connected to the points? Also a picture of the distributor from above with cap on.
ok, thanks... good to know
I've got the distro bolted, but able to be turned
Dwell meter: I'm suspecting maybe it's not working, because I haven't gotten the needle to move one bit yet
R
Did you correctly install the plug wires 18436572
Being my 1st time setting points, are they so finicky that I wouldn't be able to get even a sputter from the engine unless it's set 100% precisely?
Because I adjusted that dwell all over the place, and the engine never tried to start
Asked earlier for pictures of cap and points
I suggest ending this thread, since spark is no longer an issue.
But, I'll re-verify TDC, & where the plug wires are going etc.. then I'll set the point gap, & go from there..
If I just can't get anywhere, maybe I'll look at creating a new topic..
Rich
Rich
