My 1980's Cooling System Is Cursed.
Fingers crossed.
I called Leadfoot Racing (shroud maker and Champion Rad distributor) and asked if they would be willing to make a shroud for the rad that didn't have the louvers and that had the flap cutouts. They sell other shroud designs that have the flap provisions. They also offer customization services for the Champion radiators that they sell. They are willing to hack up and customize a radiator for people (for a fee) but they weren't willing to change the design of the shroud that they supposedly make. ...right. Thanks guys.
Oh well. So I bit the bullet and modded my Ledfoot Racing shroud with the louvers. I measured my blank spaces and determined I had enough room for 4 flaps on either side of the fan. Each flap could cover two 1 7/16" holes easily and still have material left to support the flap and keep it from getting sucked inward. This is what I came up with...
I was a bit careless when I took the shroud out and the a-arm bolt put some scratches in the shroud. A scuffing with a scotch brite pad, some primer, and some DE1634, and this was the end result.
Same paint as most of the front engine parts and accessories so it should blend in nicely.
I'm giving the paint another day to fully cure (kinda cool and humid here) and I'll slip it back into the car with the flaps either tonight or tomorrow night. We're getting up to 75* on Friday and I'm off, so hopefully I'll learn something that afternoon.
I've also driven it to work a few times in ambient temps below 55*F. Last Wednesday the 22nd and today, the 27th. The fan had even less trouble pulling the temps back down when stopped or in traffic thanks to the cooler air. On the freeway, the water temps will get sucked way down and will slowly cycle between 165*-173*. The 3-row Champion radiator is doing some work! The car has NEVER, and I mean NEVER, run this cool before in cold temps. Even with the old scaled-up radiator and factory fan setup, the coolest it would ever see in cold temps would be ~182*F. I'm taking this as evidence that the modded shroud with the flaps and holes is now allowing the new radiator to breathe properly. I still want to drive it again on a hot day to make sure the curse is gone, but I think we've got it!
I will update this thread in the future when I get another hot day to drive it.
Potential Conclusion: I traded a problem that created my symptom of hot weather freeway temp creep for another problem that created the same symptoms. I traded an inefficient scaled-up (bad) copper radiator and factory (good) shroud and fan setup for a new, efficient aluminum (good) radiator and flat shroud (bad) and electric fan setup. The old radiator couldn't shed the heat the engine was producing, and the new shroud was choking or stalling the airflow through the radiator at freeway speeds. Adding vent holes and flap covers to the shroud seems to have been the answer.
I know this has been a thread full of long, detailed, and probably excessively wordy posts, but I greatly appreciate anyone who took the time to read and offered help or advice to track down and solve the problem.
Friday the 17th was the day before my 36th birthday, so I drove the car over to In-N-Out for a treat (double-double animal style, extra grilled onions, no rabbit food, medium Dr. Pepper) and then to my favorite cigar lounge for a victory dance...
I'm glad someone got the diagnosis right in post 8, and that the fix worked.
Tell the folks that sold you the baking sheet to change their design. Or sell your own baking sheets with flaps!
Mt current stock L82 with an Aluminum Champion Rad. barely gets to 180*on a hot summer day.
If anybody is looking for a single fan I would recommend the Mark VIII. You can see how it's built here from a post when I was replacing the electric motor. No flaps and a wide open support structure.....so not sure how they do it considering lots of fan assemblies have quite the shielded shroud.
https://www.corvetteforum.com/forums...post1600032492
It was a Car & Driver road test of new 1970s, an LT-1 and an auto LS5.
Duntov said the LS5 started to run hot with the A/C on at continuous 140mph speeds!
He had the fix on the shelf: "a shroud with flaps"
But the accountants nixed it!
I guess accountants don't drive Corvettes, or 140!! LOL
My bad...it was the 71 models...
I have the flaps on the way, and am thinking about adding a piece to limit their "open flap distance" to 1/4 - 1/2" or so... Only if there i a concern with the flaps opening too far, that is.
