454 performance
Old Jan 22, 2003 | 02:53 PM
srmcclean's Avatar
srmcclean
Default 454 performance
Ok guys give I want to hear your performance recipes for the 454. I am starting with a 1987 peanut port head 454 (originally a TBI motor). I do not plan on revving past 5000 rpm. My goals are conservative but I would like 340 horspower at the flywheel and at least 450 lb ft. I would like the power peak to be around 4000 rpm. What cam along with a 750 quadrajet, performer intake and headers will get me to my goals. :D
Old Jan 22, 2003 | 06:35 PM
Ganey's Avatar
Ganey
Default Re: 454 performance (srmcclean)
Hedman headers will work fine & good for much more.
Comp Cams 270H or XE268 will put you over as your goals are too low. They are good min. 454 cams for autos.
:cool:
Old Jan 22, 2003 | 08:30 PM
The Money Pit's Avatar
The Money Pit
Default Re: 454 performance (Ganey)
I've used the Edelbrock Performer cam before in a Poncho 400,and it would pull 5000 easy,idle like stock,and I'm sure was better than 350hp.I'd have to agree that your sights are a bit low for that much motor.You realize your gas mileage is dependant on displacement. You may as well pull 450-500hp if you're going to get 10mpg anyway. :yesnod:
Old Jan 23, 2003 | 10:25 AM
bence13_33's Avatar
bence13_33
Good god, 340 horsepower should be a walk in the park even with a "broomstick" cam.
So you are going to be using the P-Nut port heads? The cams that Ganey recommended should work fine for you because those P-Nut heads are going to be done making power around 5000RPM if not slightly sooner.
Old Jan 23, 2003 | 10:35 AM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
as you are very conservative on RPM , (5000) The xe262 , range is 1300/5600 rpm, the xe 252 is a 5000 rpm cam , with monster tourque will work with peanut heads...just my 2 cents :seeya
Old Jan 23, 2003 | 10:48 AM
fredfryguy's Avatar
fredfryguy
Hey! I just did the following mods with oustanding results to my 454 LS5 engine. I had a valve job to the stock heads and added a 268 Comp Cam kit ( new springs, lifters, timing chain, retainers, etc), new Comp Cam roller rockers and pushrods.
The seat of the pants were AWESOME. It is smooth, powerful and free reving. Best results I ever experienced in modifying an engine! The motor stock is 365 HP and I think it must be pshing 400+. I'll probably dyno this spring. By the way the car is a 71 TT, 454, 4speed. Good luck, Fred the fryguy :steering: :D :cool: :cheers:
Old Jan 23, 2003 | 02:39 PM
srmcclean's Avatar
srmcclean
Thanks for the reply guys, I hope the guy hasn't sold the 454 yet I can't pick it up until tommorrow evening!! If I get more than 340 horsepower I will be thrilled.
Randy :cool:
Old Jan 23, 2003 | 02:54 PM
75 BBC Stingray's Avatar
75 BBC Stingray
It seems like everyone is recommending the Comp Cams product, but I'm buying either the Crane "PowerMax Hydraulic Roller HR-288-2S-12 IG", or their solid roller "SR-238/350-2S-12 IG" (very similar to hydraulic, but slightly more duration/lift)
There was a nice build article using the hydraulic roller in the "How to build Monster BBC's" book. When I plug the cam into DD, it has a nice torque curve to about 4,200RPM.
Old Jan 23, 2003 | 04:26 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Randy :cool:
Hang around here long enough & you'll be shooting for 600! :lol:
Old Jan 23, 2003 | 04:38 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: 454 performance (1970 Stingray)
Randy :cool:
I agree soon it will be 340 HP for one side of the motor and 340 HP for the other :lolg:
To 454 performance
