71 LS5 Fuel delivery problem
Old Oct 10, 2023 | 12:13 PM
Stallzer's Avatar
Stallzer
Default 71 LS5 Fuel delivery problem
Ive run into an issue where after driving about ½ hour to 45 minutes the car starts sputtering. It's stranded me a couple of times lately but after letting it sit for 10-15 minutes it fires right up.
When cruising the vehicle just start sputtering and if I step on the accelerator the carb gets an occasional fuel burst but not enough to keep it running.
It has the mechanical 3 port fuel pump so I don't think it's vapor lock. The carburetor is a Sean Murphy industries Quad jet flowing at 850 CFM. My mechanic also thinks it's not vapor lock but thinks the carb needs to be rebuilt.
What would cause the carburetor to act like this when running warm / hot ?
It is a 1971 LS5 with the 454 and 4 speed manual.
Old Oct 10, 2023 | 12:43 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
What is your timing set at?
Next time it quits....hop out real quick and look down the carb.....give it a few pumps and see if you see fuel squirting in......if so, then it's ignition, if not, then it is vapor lock or a restricted fuel supply.
Jebby
Old Oct 10, 2023 | 09:26 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
30-45 minutes is a long time for a fuel issue to become troublesome but not that long for an electronic issue. What distributor set up do you have? Points/condenser or Pertronix-type or later model HEI or ... ?
Old Oct 10, 2023 | 11:33 PM
Stallzer's Avatar
Stallzer
Pertronix. When it does have it's issue there is no fuel getting into the carburetor. The last episode I started it cold and made it 70 miles. I got it onto the shoulder and waited around10 minutes. Got it started, made it to the next off ramp (Was on interstate), parked it in a lot for 20 minutes or so.
Inserted key and car fired right up. Let it idle for about 2-4 minutes with no issue. Got back on interstate and made it 15 miles before it happened again.
Before the trip I was having the same issue so I replaced the fuel filter which was quite dirty so thought that would take care of it.
Old Nov 5, 2023 | 08:20 PM
Stallzer's Avatar
Stallzer
Update on this.
So the mechanic where I had it towed to was able to recreate the problem but could not pinpoint it.
What he did say is that the Carburetor had a lot of build up of a Whitish substance that he thought was from ethanol. I have a Sean Murphy Quad jet.
I'm going to pull the carb over the Winter and have it rebuilt and see what happens in the spring.
Old Nov 6, 2023 | 01:34 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I mention timing because retarded timing can elevate EGT's and make it eventually get hot under the carb......not to mention that the stock LS5 has an exhaust passage under the intake so having 800 degree heat under the carb is a recipe for boiling....this may or may not be happening but if your timing isn't at 36 degrees total....or close to.....then you are running basically a sick engine......
Jebby
Old Nov 6, 2023 | 04:09 PM
Stallzer's Avatar
Stallzer
TY Jebby.
Old Nov 11, 2023 | 02:24 PM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
What kind of coil?
Old Nov 13, 2023 | 07:52 AM
Stallzer's Avatar
Stallzer
Originally Posted by mudbone64
What kind of coil?
Apologies, this I do not know.
Old Nov 13, 2023 | 09:34 AM
mudbone64's Avatar
mudbone64
No problem.
I don't know a lot about Pertronix ignition but I do believe it requires a full 12 volts. If the ignition coil is oil filled (stock type) and receiving a constant 12 volts the coil will become so hot you won't be able to touch it. I know this for a fact as my '72 had a HEI installed in it and then later switched back to a points distributor but the wiring wasn't corrected which lead the coil to receiving a constant diet of 12 volts. One day at a car show the car simply shut off but later easily restarted and I was able to make it home but I did have to replace the engine wiring harness to correct the issue. Your Pertronix may require an epoxy filled coil to avoid this situation.
Also, does your car have a Q-Jet? I would check is the fuel filter.
Old Nov 13, 2023 | 11:30 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
At the tank sender in the back is a 6" piece of hose that can partially collapse inside.......I had this problem stalling while running down the road and tried all kinds of ****.......this is with the 66' L-79 in the Avatar.....I replaced that piece of hose on a whim and the problem disappeared.......it is worth a look.
Jebby
Old Nov 15, 2023 | 08:42 AM
Stallzer's Avatar
Stallzer
Jebby
Jebby, looking back on the build sheets the timing is at 35. It also has the engine listed as a 489. I'm assuming the call out on my hood of the 454 is correct but it has been completely rebuilt.
The info on the dyno sheets shows - BARO: 30.1 - DISP 489 - BORE: 4.28 and some other info that is greek to me.
Old Nov 15, 2023 | 08:45 AM
Stallzer's Avatar
Stallzer
No problem.
I did replace the fuel filter and it was literally trashed with a lot of build up. I thought at that point I was finished (With this particular issue)
If I remember correctly, the Carburetor is a Sean Murphy Quad -jet 800 CFM.
Old Nov 15, 2023 | 09:35 AM
barkingrats
If the fuel filter was so clogged, the debris had to be coming from the tank. Look inside the filler neck with a flashlight and see how the bottom of the tank looks. You should be able to see through the fuel to a clean metal shiny bottom.
Old Nov 15, 2023 | 12:45 PM
mudbone64's Avatar
mudbone64
You may want to install an addition metal fuel filter between the gas tank outlet and the frame rail. My '72 would bog down when I throttled it after the carb filter becoming partially clogged. I installed the rear fuel filter and no more problems.
To 71 LS5 Fuel delivery problem
