Parked for a year, Wont start
Old Oct 12, 2023 | 08:37 PM
DrWalt's Avatar
DrWalt
1st Gear
Default Parked for a year, Wont start
About a year ago my water pump, and distributor went out. replaced both, next season. now wont start.
Getting crank, sparks fine (tested with a fun jolt to my finger), and i can see the fuel pushing out of the carb.
Any help here would be appreciated.
Thank you!
Old Oct 12, 2023 | 09:22 PM
n2h2o2's Avatar
n2h2o2
Thank you!
A lot of times when people remove or replace the distributor, they get it 180 degrees off...
Pull the coil wire off (so it doesn't start) and pull the spark plug in #1 cylinder.
Have someone turn the key on and off to turn the engine while you have your finger over the hole.
When you feel air pressure on your finger, you are on the compression stroke.
Remove distributer cap and the rotor should be aimed to the front of the car aimed at that #1 cylinder.
If it is pointed toward the firewall, you have the distributer installed 180 degrees off.
Old Oct 12, 2023 | 10:50 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Yes, except, the rotor electrode may not be pointing to #1 cylinder. However, it does have to be pointing to the cap tower where the #1 plug wire is connected. In the late-'60s Chevrolet advised service departments to reposition the distributor so that the vacuum can points directly out the passenger side of the car. Then they assigned the cap towers so that #1 wire is more aligned with #2 cylinder than #1. I believe this changed again with the HEI distributors in '75.
Old Oct 12, 2023 | 11:28 PM
n2h2o2's Avatar
n2h2o2
I agree and the tach drive needs to be positioned as well...But I gave him what he needs and what to look for...
ASE training...
Old Oct 13, 2023 | 08:19 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The assumption, when someone says, "the rotor is pointing to #1", is that the one working on the car has enough knowledge to understand that #1 on the distributor cap is what's being referred to, NOT the #1 cylinder on the engine block...........
Old Oct 13, 2023 | 09:05 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Does it pop, buck, do anything?
What does the gas smell like......?
Jebby
Old Oct 13, 2023 | 09:58 AM
barkingrats
On a forum dedicated to enthusiasts of all skill levels, we shouldn't make any assumptions! Additionally, my comment was in response to "rotor should be aimed to the front of the car aimed at that #1 cylinder" which is why I clarified that the rotor should be aligned with the tower and to forget about the block. Too many variables since these cars rolled out Chevrolet's doors to assume the configuration is still the same for anything.
Old Oct 13, 2023 | 11:26 AM
n2h2o2's Avatar
n2h2o2
After working on countless sbc's over the last 45 years or so, I have rarely seen the #1 plug wire toward the firewall...
I only see this when Bubba has been under the hood, rotating wires instead of stabbing the distributor correctly...
Yes, the #1 could be anywhere on the distributor, but the OP removed the distributor and replaced it.
This makes it the #1 suspect to his problem.
We have to ASSUME that he did not rotate the engine with the distributor out, getting his rotating assembly out of sync with the oil pump....
This gives him two possibilities when dropping the distributor.
If the OP followed these directions, they would have a response/ Either it worked or it didn't.
If it didn't, we could go from there to more detailed diagnostics, to determine where the rotor is pointing at #1 @ TDC on compression stroke.
If you want to be "correct" according to the AIM, rotor should be "aimed" at the #2 cylinder. (front of engine, toward passenger side)
I am not sure why everyone has to be so contrary and trivial on this site, when we are just trying to help other members diagnose and make suggestions remotely.
I could have also told him how to balance and blueprint an engine, but was afraid the internet would run out of ink...
Old Oct 13, 2023 | 04:45 PM
KapsSA's Avatar
KapsSA
I'm assuming that it ran after the repairs last season.
I store several cars for folks over the winter. Quite often, even when seeing gas squirt in the carb, no start. It helps to prime the carb with a squirt of gas directly down the air intake of the carb.
Starts right up.
Old Oct 16, 2023 | 07:01 AM
cottoneg's Avatar
cottoneg
My 2 cents.
The gas is a year old? Did you add a stabilizer?
To Parked for a year, Wont start
