Working on a 69 Vette and am in need of a front suspension kit. I'm looking for 'standard' stuff like ball joints, tie rod ends and bushings and would like US made parts. I checked out Van Steel but it appears they may be having trouble getting Moog ball joints.
Not aware of any good "Kits". Best bet for quality parts is order individually. Try Rock auto for Moog joints. And other auto parts places. Make certain you specify USA made Moog. Not all Moog joints are US made. Rubber parts. Contact Bairs Corvettes.
Originally Posted by Mooser
Forget about "kits", realistically forget about US made.
Check your local NAPA, Rockauto, summit, etc
MOOG K6035 (2x) (ball joint lower)
MOOG K6034 (2x) (ball joint upper)
MOOG K5196 (2x) (control arm upper)
MOOG K304 (1x) (arm lower, does both sides)
MOOG ES323L (2x) (tie rod inner)
MOOG ES323R (2x) (tie rod outer)
MOOG K6100 (1x) (Idler arm)
M
Thank you both for the input!
I'm giving the owner the list above and telling him to look around, but realistically Rock Auto seems to be best bet so far. I may swap the bushings out for ploy ones, but other than that it will all stay the same.
Select poly carefully. There's a lot of people having them simply come apart. I'm not sure it or who makes a good reliable one these days but surely someone does...
M
