? on correct air cleaner
Old Jan 22, 2003 | 11:58 PM
Makonut's Avatar
Makonut
Default ? on correct air cleaner
My 70 is serial number 10498 produced in May of 70.What is the correct air filter assembly for the car. Open assembly or the dual snorkel.
Old Jan 23, 2003 | 11:13 AM
72GACRZR's Avatar
72GACRZR
Default Re: ? on correct air cleaner (Makonut)
My source says "the majority of the 1970 vettes use open element, 70's assembled after mid June 1970 except LT1s use the 1971-1972 closed element." You therefore should have the open one.
Source "Corvette restoration guide 1968-1982" by Richard Prince
Hope it helps :seeya
PS: this type question usually gets answered faster in the restoration forum.
Old Jan 23, 2003 | 07:57 PM
ED DINAPOLI's Avatar
ED DINAPOLI
NCRS reports that "after about serial number 12,000" a closed element was used except on the LT1 and LS6. So yours should be open.
Ed
Old Jan 24, 2003 | 08:38 AM
RMVette's Avatar
RMVette
Mine's the dual snorkel. :steering:
Old Jan 24, 2003 | 08:58 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: ? on correct air cleaner (RMVette)
Mine has an open element. I don`t know if it is original or not but it does have the AC Delco stamp under the lid so I assume it is original.
To ? on correct air cleaner
