78 Cruise Control
Anyone experience this or have any thoughts?
Pat
when mine does work it works fine I just have a problem getting it to engage
Pat
Here is a TEST to determine if your transducer is receiving a signal from the cruise switch, and that the solenoid is actually energizing.
You will first have to remove the spring clip and rod from the Carburetor (RED X). Only for testing so the engine will not rev when Servo pulls in.
Then remove the 2 wire connector from the Transducer and rotate it so that the White wire lands at the HOLD terminal of the Transducer.
Brown wire will not be connected to ANY terminal...
This bypasses the LOW SPEED transducer contacts.
Start Engine, have someone press the cruise switch, Transducers Solenoid MUST energize and the Servo starts pulling in.
Release switch Servo should return to its home position.
Do this test many times just to see if the operation is consistent.
Hunt:
You have Port A & Port B on the Transducer
Follow Port B vacuum line back to the intake 3 way fitting.
Make sure that hose is not kinked or internally blocked or partially blocked in any way.
Hunt:
Pat
I could prove this was the problem pulling up on the brake pedal, and then cruise would work again.
I could prove this was the problem pulling up on the brake pedal, and then cruise would work.
