After trailering my 1968 C3 I have found that the tail lights and turn signals don't work. The emergency flashers are working. All fuses in the main box are working. Any suggestions where to hunt for problem?
Look at your grounds, everything is in reference to ground or bonding wire underneath at the rear of the car. Im not sure exact location, I would have to look at mine, but have a look around
They run on 2 different circuits. Look at he fuse block . I just went tru this and even thou the fuse were new I swapped them anyhow and it lit up . Sometimes it's the easy way
