Purchased another C3 it's a 1977.Been sitting for years in a heated garage , we got it running decent,now here's the issue, it is the power steering, sitting still the wheel can be turned with one finger it's almost scary it steers that easy,on the road it seems fine however you have to be careful because it's steers that easy. Now here's the issue with the wheels on the ground and trying to turn around or move the car turning the wheel in either direction sometimes will start vibrating and shaking the car till it is turned a little further once you're moving it's fine.Jacked up and with the wheels off the ground it doesn't happen seems like it needs a load on the steering I hope you understand what's going on seems like it almost has too much pressure, could it be a bad pump or control valve?
Today I changed the fluid and put a conditioner and additive in seems like it doesn't make much of a difference the car can be driven like this but I would like to fix the issue without starting to throw parts at it,you guys are the experts, has anyone out there ever experienced this problem also the system has no leaks looks like the control valve was changed at one time does
not look like the original
thanks guys
I have a 77. Doesn't do this. Yes I have always put in as much caster as shims would allow. Recently added offset and slotted upper A arm shafts. Even more caster. Even better.
start with your alignment. Could be tires sticking under load caused by a complete lack of caster. Good place to start. Shoot for as much caster as you can get!
You will get some action in the steering wheel at lock....left or right.....you are still tripping the power steering valve at lock but it can't go any further.....so it "shudders".....remember, this is a hydraulic system, and the force generated at that ram is considerably high and has potential to be much higher when limited.....hydraulic pressure spikes at lock.....like 4x if I remember properly.......so I believe you are knocking it against the knuckle stop on the control arm, and it is fighting you back.
The advice on caster is a good one........a properly aligned Corvette will track straight, hand off the wheel, at 100mph.......
I bet that someone let the P.S reservoir run dry. You have an air pocket in the control valve. And / or an air bubble in the slave cylinder.
You changed the fluid, but did you bleed the system? Those air bubbles can lead to what they call a "shimmy". The control valve & cylinder is not getting constant pressure on both sides of the ram piston. On again / off again.
I believe a good 12 - 15 mins of bleeding the system help.
I bet that someone let the P.S reservoir run dry. You have a a air pocket in the control valve. And / or an air bubble in the slave cylinder.
Thanks for the advice,is the correct way to bleed the system turning the wheel right to left all the way you say for 12 to 15 minutes? should the tires be off the ground jacked up or on the ground
It kinda sounds like someone installed a new power steering control valve but didn't balance the slave cylinder...
Try this adjustment procedure in the video and see if this solves your problem.
Yes, wheels / weight off the front suspension. Then several lock-to-lock steering wheel cycles. Don't add stress to the system when parked.
That should do it, unless there is a leak somewhere allowing air back in.
Just got done centering the cylinder went through the bleeding process but I read your email too late wheels were on the ground not off the ground one thing I noticed according to the video once the cylinder is balanced you should be able to move the cylinder rod in and out easily, mine you had to struggle to move it out and in once it was balanced. What do you think do I have a bad cylinder?
Should l bleed the brakes with the wheels off the ground and try again?
Not only will the rod be dead center in its travel length, but the rod should easily move by hand before you attach it to the frame.
Somethings still not right. Is it a bad cylinder? Hard to say. It takes its commands from the C. valve. So, technically the C.V. could be at fault.
You should never stress any PS system whether it's a daily driver or your C3. What I mean by that is allowing the weight of the cars tires rubbing on concrete or blacktop. That puts a horrible strain on the tie rods, drag link, pump, etc. Always roll the vehicle a bit before turning the wheel.
If you do not want to lift the front for burping the PS there is a trick. Go to a dollar store and buy four self-stick floor tiles.
Peel the backing off one tile and stick it on the floor just in front of the tire. Place a big gob of grease on the tile. Take the second tile, peel the backing and place it up-side-down on the grease.
Drive up on the tiles. You now have a turntable that will swivel with the front tires.
Keep the tiles around. They can be used for setting rear tire camber on the strut rods. No friction.
