About to pull the trigger on a BP 3505CT crate engine on a 74 vette. Going with weiland 8125 and stock exhaust manifolds. BP says there heads are 1 inch wider total at the exhaust flange do to raised boss. 1/2 inch each side . Do you see any issues with this it looks like i have clearence..
I don't know the specifics or your proposed engine, but be sure to confirm these:
I don't think you will have a clearance problem with stock manifolds.
Some headers might be tight..
A different concern...
I would look at the alternator mounts / accessories to make sure your belts line up...
Another issue may be the height and air cleaner / hood clearance.....
Seriously???? 1/2 an inch wider flange on a 23 degree head? On a motor that makes only 390 hp. If that’s the case I would seriously look at something different.
Might have clearance issues with the exhaust pipes, etc etc.
