Gas Pedal for Amputee
Old Nov 19, 2023 | 09:48 AM
Reggie Hohenberger's Avatar
Reggie Hohenberger
6th Gear
Default Gas Pedal for Amputee
Hi folks need some help.
i will soon have my right foot amputaded to due cancer.
Any suggestions on switching the gas pedal to the left side. I have a 1973 coupe, automatic.
Thanks, Reggie
Old Nov 19, 2023 | 10:00 AM
n2h2o2's Avatar
n2h2o2
Hi Reggie,
Sorry to hear about the cancer...
I think if I were faced with this, I would keep the pedals as is and learn to drive in the stock configuration.
I guess my thought would be that I could drive any car that was not converted...
If I did modify anything, I might look into bending the brake pedal a little to the left and maybe move the gas pedal to the left...
But I would probably leave as is for the first reason.
Good luck, and keep the faith!
Old Nov 19, 2023 | 03:45 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
it takes practice but I had friends with broken legs drive left footed and I have done it with foot injuries as well. Practice a lot so it becomes second nature and you will be good in any car, that way you wont be stuck with just one vehicle
Old Nov 19, 2023 | 03:49 PM
gearheadib's Avatar
gearheadib
How good are you at fabrication? Im sure a pedal could be made to work the gas with your left foot.
Old Nov 19, 2023 | 03:55 PM
roscobbc's Avatar
roscobbc
Really sorry to hear about your impending amputation Reggie - why not leave things as they are and 'mirror' the stock gas pedal with a 'hand' throttle mounted on a fabricated bracket attached to steering column casing behind steering wheel ?
Old Nov 19, 2023 | 05:13 PM
71 Vert LS1's Avatar
71 Vert LS1
Don't know if this helps but on last weeks "Octane and Caffeine " a car show on Motor Trend they roam around a big car show in Atlanta and look at cars and interview the owners. As I recall they talked with a guy that had hand controls for the throttle. The throttle lever (like a column shift auto stick) was mounted on the right side of steering column and thru some rods and bell cranks it put pressure on the stock gas pedal. The gas pedal and location looked totally stock.
Old Nov 20, 2023 | 05:21 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm thinking along the lines of drivers Ed. cars. Ya know how the instructor had a brake pedal on the passengers side so the teacher can nail the brakes if necessary? Some sort of bar clamped to the stock pedal and goes sideways to the other side of the car.
Thinking this sort of idea, just way shorter and going left to put a second gas pedal left of the brake.
Old Nov 20, 2023 | 06:43 AM
BKarol's Avatar
BKarol
Search showed :
Amazon Amazon
https://www.ablemotionmobility.com/b...ot-accelerator
Don't know if it would work in a Vette but Amazon has a very easy return policy. Could place it in your Vette for a test. Good luck.
Old Nov 20, 2023 | 09:52 AM
gjohnson's Avatar
gjohnson
or handcontrols would work
Old Nov 20, 2023 | 10:33 AM
Rabbi's Avatar
Rabbi
I used to drive with my right leg up on the tunnel and operate the pedals with left foot. Maybe you will be getting a prosthetic and solve the problem. Good luck working it out.
Old Nov 22, 2023 | 03:44 PM
GTS Bruce's Avatar
GTS Bruce
Do it. Just keep driving. The best medicine.
Old Nov 22, 2023 | 04:00 PM
Mdbirk's Avatar
Mdbirk
Saw one of these installed in a triumph stag. Very small car with a very small footwell. I imagine it'll fit in a c3 vette
The most common solution is the “twin flip” pedal tho .
https://m.youtube.com/watch?v=Zw9HVAsASHk
Old Nov 22, 2023 | 09:55 PM
Alwyn678's Avatar
Alwyn678
God Bless you, I am sorry that happened. Looks like you have some good options listed.
Old Nov 23, 2023 | 12:28 PM
Reggie Hohenberger
6th Gear
Thank You so much. This looks doable, everyone has been so kind. I have a size 13 foot, so keeping things stock might not be an option.
Reggie
Old Nov 23, 2023 | 12:35 PM
BLUE1972's Avatar
BLUE1972
You are now eligible for state help as you are disabled.
There is a manufactured product for this. I have a friend who lost a leg in a RR acident and uses the device - state paid for on his C2 and new car .
To Gas Pedal for Amputee
