Tach/Speedo backs rust removal
Old Nov 22, 2023 | 09:24 AM
69ttop502's Avatar
69ttop502
Default Tach/Speedo backs rust removal
Is there an easy way to remove the rust from the metal cans, or is it best to wet blast them. Thanks.
Old Nov 22, 2023 | 11:41 AM
Sayfoo's Avatar
Sayfoo
Some liquid rust removers will leave a phosphate finish which is somewhat rust resistant.
On my list of things to do to my '69, this would be about #10k.
Old Nov 22, 2023 | 02:18 PM
69L88's Avatar
69L88
I put on some rubber gloves, grabbed a some Scotch Brite pads and some CLR. Took care not to damage the factory labels, then sprayed with Boeseal.
Old Nov 22, 2023 | 03:54 PM
interpon's Avatar
interpon
Not sure what you are trying to remove but i would use evaporust above 70f and soak..
Old Nov 22, 2023 | 06:12 PM
Mooser's Avatar
Mooser
I masked all the inside off and blasted mine with a fine glass-bead but I was painting them afterwards so I didn't care about the finish being original or anything.
M
Old Nov 24, 2023 | 11:28 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
This is great stuff and good to have around...
https://www.ospho.com/
Home Despot has it in quart sizes I believe.
To Tach/Speedo backs rust removal
