Speedometer Problem
Old Nov 24, 2023 | 03:06 PM
T Dale's Avatar
T Dale
Default Speedometer Problem
1974 with 3 speed automatic. The original cable was obviously bad so I replaced with a 2 piece cable. When spinning the speedometer end of the cable by hand, the needle moves. Before attaching the other end, I pulled the housing and checked the gear (it was fine). The other end of the cable that plugs into the transmission will not move by hand (so I guess the nylon gear is not spinning against a stripped metal gear. Any thoughts for what to check next? I am flummoxed.
Old Nov 24, 2023 | 04:00 PM
HeadsU.P.'s Avatar
HeadsU.P.
Two piece cable? So you are using Cruise Control? Or do you mean a inner cable and sheath?
There are two gears inside the tranny, both plastic or nylon. One is a "driven" gear and the other a "drive" gear. You will not be able to spin the driven because its engaged to the drive gear. The drive gear is mounted on the output shaft to the driveshaft.
Never hook up an electric drill to the speedometer end of the cable. You will damage the transmission end. You can hook up a drill to the tranny end to check for speedometer needle movement. Which you did.
If you are running cruise, good chance the internals of the transducer are compromised.
Old Nov 24, 2023 | 04:22 PM
T Dale's Avatar
T Dale
Yes, a two piece cable without cruise control. That was what was on the car. When it did not work after installation, I detached the coupler in the middle of the cable and only spun the cable on the speedometer side by hand-no drill. The needle moved. I tried to spin the gear side of the cable by hand, but it did not move which is why I don’t think either the drive gear or the driven gear is stripped. The only thing I did not do is engage the transmission and see if the cable is turning where the cable joins in the middle while detached.
Old Nov 24, 2023 | 07:04 PM
HeadsU.P.'s Avatar
HeadsU.P.
Sounds like at one point there was cruise on this car? Or someone bought the wrong cable. And it sounds like somebody joined the two with a coupler instead of buying the correct cable. Perhaps they didn't want to crawl under the dash and wrestle with the speedo connection. (not fun)
I did away with C.C. and bought a single long cable.
There are several choices of cables.
4 speed w/ cruise (2, upper & lower)
4 speed w/o cruise
Auto w/ cruise (2-upper & lower)
Auto w/o cruise.
You only need a single cable. It will be part listed as a lot longer instead of two short ones for cruise. No need for any coupler.
Old Nov 24, 2023 | 08:46 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
... You only need a single cable. It will be part listed as a lot longer instead of two short ones for cruise. No need for any coupler.
The two-piece cable is standard for the M40 (TH400) auto trans. I don't know if the later appearing TH350 had one-piece or two and cruise control wasn't offered until '77. I've no clue as to why the engineers chose 2-piece for this since I'd think single would work equally well, but there must have been some significant reasoning behind it. (edit: Maybe the single cable isn't long enough?)
Here's the '72 AIM showing its installation:
Old Nov 24, 2023 | 09:40 PM
T Dale's Avatar
T Dale
Thanks for the responses. I’m going to try to do some more detective work on Sunday. Any other suggestions are appreciated and valued. It’s really bizarre that it is not workng.
Old Nov 25, 2023 | 09:36 AM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
Can't help you, but i have the exact same problem, but mine is a 4 speed.
Disconnect at trans and turn cable by hand and speedo works.
Disconnect drive shaft and with it in neutral turn output shaft and speedo gear turns.
Hook up cable at trans and disconnet at upper lower cable connection and turn trans output shaft and opposite end of cable is rotating.
Make all connections and turn trans output shaft and speedo does not work.
Take it for a drive assuming I'm not turning output shaft fast enough, still nothing.
At this point, thinking of just putting a one piece cable in and seeing if that works.
Old Nov 25, 2023 | 10:23 PM
vbgod1's Avatar
vbgod1
Just tossing a thought out…
I fought my 78 auto with about the same results for almost a week, off n on. Turned out the drive gear in the tranny had slipped down some. Looked ok, since I did not know exactly what I was looking for. I guess at a slow turn by hand, it was ok. At speed, it missed the teeth to turn.
C
Old Nov 26, 2023 | 09:22 AM
HeadsU.P.'s Avatar
HeadsU.P.
You mean the driven gear dropped down? Which is fairly easy to remove.
The drive gear is clipped on to the output shaft and requires driveshaft removal, tail-shaft housing removal, bracing the trans mount, etc, etc.
If that steel clip on the drive gear ever broke off, then . . . . . . . .
Old Nov 26, 2023 | 11:13 AM
vbgod1's Avatar
vbgod1
Didnt break, but must have stretched. I put it back, it did it again, so I got a new one. Been fixed for over a year now. It sure was fun figuring it out.
Go Wildcats! 81
C
Old Nov 26, 2023 | 02:35 PM
T Dale's Avatar
T Dale
Found the problem. The teeth on the driven gear were fine, but the bottom of the gear where the wire goes in WAS stripped. Thanks everyone for the replies.
Old Nov 26, 2023 | 05:07 PM
HeadsU.P.'s Avatar
HeadsU.P.
I have seen several speedometer cables with a spring-loaded tip that goes into the tranny. It fits into what they call the bullet.
I recall that spring is a sacrificial part. Supposedly, if there is an issue with any cables or the speedometer cluster gears, that spring will sacrifice itself.
Much easier & cheaper repair than the latter.
To Speedometer Problem
