C3 lower camber rod-shock bolt question
Notice the flat on the shaft and the orientation of the mount.
4-vettes (12-01-2023)
Looks like the flat side where its threaded is on bottom in your picture. The spindle also has a flat area, you will see on the backside bottom. Heres a pic of mine if it helps when lookng at the shock mount you can see the flat area.
