I already have a 2004r tranny,although needs to be opened up and gone through,and was looking on marketplace and found a new TCI street fighter torque converter new for sale for $200 and they go for about 600,it’s stall ratings is 2200-2600,which is what I think I will need,for about 350-400 hp,and 3.54 gears. I’ve seen good and bad things about TCI,but,they are a good,quality converter correct,thanks.
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I...Had a 11.5" TCI TC long time ago, what a POS boat anchor it was for a 2400. It was very lose and seemed like driving around towing something at light throttle. Now, I have a Yank SS 3200 9.5" and drives like a stock TC until you hit the loud peddle and then yeeha! You would never know it's a 3200. I'm actually going to have the 3200 re-stalled to 3500 for $300 so that it works out perfect with my setup after doing the math and a lot of launches. Best 60' has been 1.7, shooting for a 1.6 or better. Each to their own, but since I actually had one and was very disappointed with it, I would never use TCI again for anything.
They (TCI) are actually known to NOT be a quality converter. Check out Yank, Ultimate, ATI, Circle D etc. With TCI, you might get a stator that makes it very loose around town at low throttle and has more slippage at high rpm when you actually want less. The converter is the most important factor in how your car will drive--it is worth spending more and getting a quality unit.
Yep,that’s what I needed to know,thanks,and bikespace I have bought a lot of stuff on marketplace,FB mostly golf clubs though,but did recently buy a 1972 GTO on their. A lot of people sell on FB,and it’s actually a good way to get great deals on things,but I guess to each is on.Im by no means cheap,sometimes I wished I was,but if something is new and I can save half the money,I’ll take that everyday.but,you do have to be careful also when buying on their.
Stall speed is a guestimate so call the Converter manufacture not Jegs for best results but to give you a recent example is I just installed a close ratio gear set in my 700R4 and installed a new Torque converter at the same time , I took out the stock 1650 rpm converter and installed a factory replacement S10 pickup 4.3 V6 TC into my 1980 L82 with aluminum heads and Comp XE262 cam , rated stall for the 4.3 V6 was 1950 rpm stall but with my 10 to 1 compression 355 it stalls 2250 to 2300 rpm so that gives you an idea about a 1950 to 2300rpm stall speed guestimate , if I had a really big cam with not much torque down at low rpm then my stall speed would be much lower than the 2300 rpm I have now
On my LS swaps I have used Yank and Circle billet converters. Both have worked have worked well. My builds are fairly mild. So the stall speed is 2800-3000. As said above they drive like a stocker until you floor it.
