68 Convertible Top
Old Dec 20, 2023 | 12:07 PM
76yellow's Avatar
76yellow
Default 68 Convertible Top
I have been installing an Al Knoch top this week according to the video. Things seem to have gone pretty well until I put it on the car. I cannot make it latch to the deck lid even with the latch pins screwed out as far as I can. The rear seal seems way to thick to squeeze down enough !!!! I ordered a seal from Zip hoping it will be softer or thinner. If not, i don't know what to do. Any suggestions ?
Old Dec 20, 2023 | 12:29 PM
Sayfoo's Avatar
Sayfoo
I had the same problem with the repo seal. Too thick and too hard.
My observations.
When raising the top, I must latch the rear before latching the front. If I do the front first, the pins do seem to be too short.
The hard seal will eat into the paint on the deck lid. You'll get a nice line/groove all across the deck lid, probably from the seal's vibrations. Get a clear plastic applicae that self adhears from most any corvette parts shop.
Cold weather makes the top harder to operate.
I use a rolled up bath towel to lay in the crease of the back window, to decrease scratching, when putting the top down.
Post your resultls on the new seal when you get it.
Old Dec 20, 2023 | 08:39 PM
76yellow's Avatar
76yellow
Thanks Sayfoo......I talked to AlKnoch today. They wanted pictures of my install so I sent them. Haven't heard anything back yet. They did say that the new seal I ordered from ZIP will be the same as what came in their kit. he said all of the seals are the same...same manufature !
Old Dec 20, 2023 | 10:05 PM
n2h2o2's Avatar
n2h2o2
Perhaps drop the frame mount down a notch or two?
All the verts I have owned took a little weight to stretch and latch on the rear deck.
The clear film on the deck is always advised. Dust is very abrasive.
Old Dec 20, 2023 | 11:13 PM
Eliredandblack's Avatar
Eliredandblack
I bought a new rear seal for my 73 from Top Flight and it is a bit thick. Over a period of time the new rubber will compress. Like the others have said, get the rear to latch First, and then proceed to the windshield latches. Without the front latches, you should be able to get the pins to latch. My top is around 4 years old and I still have to push hard to get the rear pins to hold, you want a tight fit to keep out water and wind. I would say my top is a good inch above the rear deck because of the rear rubber seal. I am guessing you don’t have the old seal? There is another company that makes rubber weather stripping, you may want to try Google to get their name, and give them a call.
Old Dec 21, 2023 | 09:08 AM
76yellow's Avatar
76yellow
Al Knoch told me all the seals are the same no matter where I get one from ! I haven't even finished installing the rest of the top to the frame. So the front has nothi9ng to do with it not latching to the deck lid. I sent them pictures of my rear bow seal install and waiting to hear if I did something wrong. I went step by step according the video !
Old Dec 21, 2023 | 06:24 PM
mrg's Avatar
mrg
My observations.
My car is a C2 but has the same soft top issues. The rear deck pins need to go in first and click stop on the first notch.
Getting the front guide pins started into the header strike, a short piece of round stock was modified to include a notch that engages the guide pin.
For mechanical advantage, fingers holding the front top frame header bar down, the round stock goes in at an angle through the strike to engage the guide pin and bring it forward enough to engage the strike.
The vinyl soft top fit is a bit a on the short side, likely part of the problem.
Thin vinyl plastic rear deck strips were also installed to keep the rear rubber gasket from digging into the rear deck paint.
Jin
Old Dec 23, 2023 | 05:35 PM
pltmgr's Avatar
pltmgr
I ve done two convertible tops on Corvettes and one on a Jeep Wrangler. Every time I had difficulties latching the top. Leave the vehicle in the sun if possible. Once latched leave it for a few days to stretch it out. The first time i did it there was a foot gap between the top and the rear deck making me think I had the wrong top. As already suggested latch the deck first.
Old Dec 28, 2023 | 11:18 PM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
Are you able to see the clear film protector when it's installed on the car?
Old Dec 29, 2023 | 01:24 PM
Sayfoo's Avatar
Sayfoo
I guess it depends on where/how you apply it.
They are about 2" wide, and you can apply it so it doesn't protrude around the outside. I've never really worried about the inside. They are clear, and stick down to the deck lid, so they are not really obtusive even if they stick out. Also, they can be easily cut to whatever dimentions you'd like.
I've had 2 different ones. 1, a 2 piece that overlaps in the middle, and 1, a 1 piece. Both worked well, but I think, overall, the 2 piece is preferable.
Old Dec 29, 2023 | 01:37 PM
DWAVette's Avatar
DWAVette
Does the film stick down like packing tape, or Siloam, that may peel up paint if you pull it up?
Do you recall a brand or source?
Old Dec 29, 2023 | 02:31 PM
Two Red Vettes
Is the protective film obviously seen on the deck when the top is up?
Old Dec 29, 2023 | 05:22 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Yes it does if you don’t get it in far enough.
Old Dec 29, 2023 | 06:45 PM
Corey_68's Avatar
Corey_68
https://www.topflightautomotive.com/...softtop-clear/
Old Dec 29, 2023 | 08:07 PM
Two Red Vettes
I'm sorry, I mistyped my question. Let me try this again:
Is the clear, protective tape visible on top of the deck lid when the convertible top is down (folded and stored under the deck lid)?
I imagine that it can be seen to some degree, but just how obvious is it at a casual glance?
Thank you, once more.
Old Dec 30, 2023 | 01:45 PM
Sayfoo's Avatar
Sayfoo
The old school film I used doesn't really stick that well. It sticks kinda like saran wrap, it just sorta clings. I pull it off when the top is down, as I think it could blow off while driving. https://www.topflightautomotive.com/...softtop-clear/
Probably, a better solution, would be to use a modern, semi-permanent clear wrap material. The edges are minimally seen, as you can see on any car that has been wrapped. More expensive, unless you could do it your self.
@ Amazon.
VViViD Paint Protection Film Clear Vinyl Gloss Self Healing Wrap Guard (17.75 Inch x 54 Inch)
To 68 Convertible Top
