Water Pump Replacement?
Jan 25, 2003 | 09:51 AM
I need to replace my water pump. What's been the CF experience with pumps from Auto Zone or O'Reilly's?
Jan 25, 2003 | 12:54 PM
Re: Water Pump Replacement? (flynhi)
ttt
Jan 25, 2003 | 01:33 PM
I put an Autozone waterpump on a couple of months ago. So far so good. The pump is new, with a lifetime warranty, and the price is right.
Jan 25, 2003 | 01:35 PM
I've had one on for about 8 months. No problems and can't beat the warranty/price.
Jan 25, 2003 | 01:37 PM
Cruise-In VI Veteran
Cruise-In VII Veteran
I just put on a $24.00 lifetime warranty long type water pump from Autozone on my pickup. I was going to use the one that came with my ZZ4, but the hub bolt pattern was different. Other than that the new Autozone pump looked just like the new GM pump. It's been on the truck for about a month and isn't leaking, yet!
Jan 25, 2003 | 01:55 PM
Re: Water Pump Replacement? (Smokehouse69)
This might be a seperate topic, but is anyone running an electric water pump on the street?
I like the idea of having one less belt & pulley cluttering the engine compartment.
D. Ocean
Miami, FLA
Jan 25, 2003 | 02:00 PM
Re: Water Pump Replacement? (74FLCONV)
D. Ocean
Miami, FLA
I`m going with an electrical pump and dual 16" fans..I`m looking in to the Meziere or CSI pumps..They sure look :cool: too :cheers:
Jan 25, 2003 | 02:22 PM
Since I have a big block and they are known for over heating I wanted to buy the best water pump I could find to minimize problems. I bought the Edlebrock Victor series aluminum pump. It has an increase flow of 20% and I use a 3/4 restrictor plate instead of thermostat. The car runs at 160 degrees even if the out side temp is 99 degrees
Jan 25, 2003 | 04:04 PM
Re: Water Pump Replacement? (wayne_69_427)
I too plan on using Edelbrock water pump :cheers:
