1980 replace air dam
Old Dec 30, 2023 | 04:03 PM
Michael Manley's Avatar
Michael Manley
3rd Gear
Default 1980 replace air dam
I need to replace my 1980 air dam. Should this one just bolt right on? Thank you and Happy New Year!
Old Dec 31, 2023 | 05:15 AM
Golfobsessed's Avatar
Golfobsessed
That is a correct air deflector for 80-82 if that's what your needing, there is also a black rubber air dam that runs under that along the entire front end.
Old Dec 31, 2023 | 07:29 AM
Bikespace's Avatar
Bikespace
Test fit and paint it before you install it. It should bolt right in.
Old Jan 26, 2024 | 01:05 PM
Tech141's Avatar
Tech141
From the pic - Doesn't look like it has the bolt holes drilled in it.....
Old Jan 29, 2024 | 09:51 AM
Golferdad's Avatar
Golferdad
I have a 1981,and that’s not the correct piece,I had to remove mine,because I replaced my heads and intake,then this wouldn’t fit,so had to go with a thinner breather to close hood,but if it’s like mine,you have to pieces top and side,with two duct pieces connecting to air breather,I took mine off two years ago,will try and find them,take a picture for you.
To 1980 replace air dam
