'74 starter issues
Old Jan 3, 2024 | 10:03 PM
Corvette_Dez's Avatar
Corvette_Dez
Default '74 starter issues
Hi all.
I've recently purchases a '74 coupe 350 A/T. The guy that sold it had a jumper wire to bypass the passenger side seat belt safety. When you started the car the solenoid would stay engaged. I pulled the jumper wire and put the relay back in. Now the car starts and runs great. The solenoid retracts as it should. However, the car doesn't actually start until you let off the key.
Anyone have any ideas on what's going on here?
Thank you
Old Jan 3, 2024 | 11:16 PM
Peterbuilt's Avatar
Peterbuilt
The 1974 Service manual has several pages on how to troubleshoot the seat belt system, see pages 12-62 to 12-77.
Do you have these parts?
Old Jan 6, 2024 | 09:29 PM
Corvette_Dez
I've got the relay under the hood with the button on it. I'll be taking apart the console to check the other.
Old Jan 6, 2024 | 11:57 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
a wire from starter feeds coil when cranking and when key is in "run" position another
wire feeds coil.
so, the wire from starter to coil is bad.
Old Jan 7, 2024 | 12:37 AM
Peterbuilt's Avatar
Peterbuilt
You might want to look at the ignition switch at the bottom of the steering column.
It could be out of adjustment or a poor connection.at one of the plugs.
To '74 starter issues
