My long ago restored '69, sometimes steers weird.
'69 BB manual, with large front sway bar, no rear bar, Bilsteins, VB&B rear fiberglass spring, 360lb??? front springs, all new bushings (25k miles ago), etc. Rides a little rough in town, but great in the mountains.
Sometimes on harder turnes, or at speed, it steers smoothly to a point, then abruptly increases the turn. Kinda like bump steering, but on a smooth road/turn.
Everything appears to be tight and working correctly.
My best guess is that something is binding up, and then lets go.
Everything lubed where possible.
Any guesses??
Stock oil pan.
Intermittant, but I think it is mostly on right turns.
Steering is fairly neutral. 1 1/8"??? front sway bar and none in the rear. Cooper 255/60/15's all around.
Is it possible that the steering assist ram is doing strange things? There's an active thread where another use has jacked up his steering by filling the power steering valve with grease.
Binding is still very likely, but perhaps run a test with the power steering belt removed (not a long test), and isolate the power steering system as a cause. The ram could be catching, too, if there are rust rings on the piston.
I’ve currently got my power steering components out for inspection and possible rebuild do to a similar condition. Are you getting to the point of body roll as this happens?
Thanks for all the suggestions.
It appears that I really need to check all the front and rear suspension for binding or loose parts.
I just need to put the time in.
I lost one of the lower front control arm bushings and didn’t know it. The car drove fine. The only clue was a “rubbing” feel that I thought was something rubbing inside the steering column until I went underneath. The lower arm had shifted and the tie rod was rubbing the control arm in one spot of the travel.
If it had gotten worse, I could see it manifesting itself in exactly what you describe.
If you were to suspect that the positraction in your differential may be causing the problem (3 on a scale of 1-10) just drain your differential by sucking it out through the drain plug hole and refilling it with genuine GM positraction additive then top it off with the correct differential lubricant. (I prefer Lucas 90/140). Then find a parking lot where you can do 6-8 slow speed figure 8 turns, then take it out on the highway and see if it had any effect on your problem.
