Driveshaft Vibrations
Old Jan 23, 2024 | 09:32 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Default Driveshaft Vibrations
Found this interesting video showing a vibrating driveshaft.
Scroll to 7 min 45 sec and listen
Old Jan 24, 2024 | 05:23 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I don't normally even look at this type of thing. Guess I was bored.
DAMN, that guy is boring.
Just couldn't watch it all.
Old Jan 24, 2024 | 08:22 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
We used Tom Wood's shafts at the Bronco shop......nice stuff.......reasonably priced for what you get.
Jebby
Old Jan 24, 2024 | 10:31 AM
Lt.Mike's Avatar
Lt.Mike
My ‘68 had a slight vibration on the highway.
last summer I blew the rear but I doubt that was the cause of the prior vibration. While I had the rear out I pulled the driveshaft to change the U-joints as long as I’m in there. Doing so I saw the trans yoke was badly worn which made sense because it did have a small tailshaft leak. The leak should’ve been a clue that there was a bigger problem.
I replaced the yoke, the tailshaft bushing and seal.
with it all together the vibration is gone.
Yes it could have been the rear, the U-joints too but the most glaring culprit was the badly worn tailshaft yoke.
Old Jan 24, 2024 | 06:57 PM
beachmusic's Avatar
beachmusic
When I was 17 I had a 1966 chevy Impala which came from factory with 427 and muncey 4 speed. It was heavy but ran really well for the time. Long story-short, I twisted the driveshaft. At 25mph the entire car would jump up and down . At 30 you could not stay in the seat. A twisted shaft generates a LOT of energy. Just a story from years ago.
To Driveshaft Vibrations
