Ball Joint Replacement Questions
However, my hope is to do this without removing the A-Arms from the car. My Haynes manual does outline a process, but seems to employ a strange tool for ball joint separation, which I don't have. I have a couple of "traditional" ball joint separators (a "pickle fork and a lever arm tool). So, my question is, is it possible or feasible to replace the ball joints with the A-Arms in situ? And if so, does anyone have a "step-by-step" guide or hints on what to do and what not to do?
Thanks!
Step 1. Throw your aftermarket manual in the bin!
Step 2. Purchase a Genuine G.M. service manual for your year car. (This will give you the step by step your looking for).
Step 3. You can use a pickle fork as you don't care if you destroy the old joint. But a ball joint tool is much nicer.
4, if your joints are original you will need to grind off a couple rivets. A die grinder with a small cut off wheel works great.
some jackstands and a floorjack along with a die grinder and a ball joint tool and your in. Basic tools like wrenches, hammer and punches will also be needed.
Then on to a alignment.
3/4" Forged Ball Joint Separator (harborfreight.com)
It worked like a charm.
I actually successfully used my pickle fork on the P/S valve job, but wasn't sure it would work on the ball joints.
I'll see if I can find the GM instructions on line - the manual is not the easiest thing to come by here!😱 The Haynes manual has been fine for 32 years, but their method for the ball joints is a bit strange!😄
Use a sharp punch on each rivet to mark the center, use good sharp drill bits and make sure to drill in the center of the rivet. You can often separate the balljoint from the knuckle with a couple good smacks with a hammer.
drilling them on the car might be a bit more work but much less chance of damaging the arm.
And almost all my tools are 50 years old and older. Most likely much better than tools purchased today!
As another guy said, if you're replacing the ball joints anyway, use your pickle fork.
I'm just starting to to replace all of the A arm bushings, (for the next controle technique), and am going to replace all four ball joints while I'm at it. The car has 129,000 miles on it, so I may as well.
Foe our American friends, here in France, a classic car, (over 30 years old and registered as a classic), has to have a safety inspection every five years. Most of the inspectors are pretty sympathetic and will allow some, um, wiggle room.
Thanks!
my experience is the lowers wear much more than uppers so maybe only replace from inspection noted?
otherwise i would put in new bushings and all ball joints unless bushings are in great shape..
bushings make a shocking difference if worn and you drive a lot by beautiful pics..
bushings can fail inspection too.
hell springs are cheap too 😆..
here is my thread if helpful
https://www.corvetteforum.com/forums...rs-method.html
To say they will be worn as well isn't likely.
Twice now I've replaced A arm bushings in my now 47 year old car. It never needed them and no improvement of any kind was realised either time.
The work may not happen quite as soon as I\d planned as a few things have cropped up here that may restrict my time a little, but we'll see....
hdeyong, I tried to drop you a PM, but it "bounced". Can I get in touch?
One of the best things about this website is the camaraderie.
https://www.moog-suspension-parts.co...all-joints.asp
You're basically lifting the lower a-arm to see if either joint shows any vertical movement in the joint itself.
