Ignition points question
Old Jan 30, 2024 | 06:58 PM
MMH2009's Avatar
MMH2009
Default Ignition points question
Greetings Fellow C3 Enthusiasts,
I am wondering what is the best ignition points to run in my stock 69 390hrs? I don't trust napa or the other national auto parts store options. Looking for the best performing option. Not interested in changing the ignition set up. Prefer to leave it stock. Thx in advance !
Old Jan 30, 2024 | 07:11 PM
Mdbirk's Avatar
Mdbirk
Never had an issue with acdelco points from napa or O'Reilly's.
Old Jan 30, 2024 | 08:29 PM
Dogmark's Avatar
Dogmark
I’m really happy with accel
Old Jan 31, 2024 | 08:51 AM
7t9l82's Avatar
7t9l82
The only.issue I ever had with Accel. Points is the spring tension wears the rubbing block faster meaning you need to readjust more often. Mallory probably still makes them. There are other options but that's your choice
Old Jan 31, 2024 | 09:25 AM
7t9l82's Avatar
7t9l82
Good luck
Old Jan 31, 2024 | 10:53 AM
MelWff's Avatar
MelWff
You are mistaken on your NAPA comment. Ask for CS7860 points, they are for high rpm applications.
Old Jan 31, 2024 | 11:30 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Even the standard CS786 will do just fine; the 7860 has a higher spring tension.
Old Jan 31, 2024 | 01:20 PM
sunflower 1972's Avatar
sunflower 1972
I know lars likes the Napa - Eichlin brand of ignition. A thread from about 5 years ago:https://www.corvetteforum.com/forums...on-points.html
Old Jan 31, 2024 | 08:19 PM
Mooser's Avatar
Mooser
I ran the NAPA/ECHLIN CS786P for a long time without any complaints (prior to switching to pertronix, then back to points, then to MSD/HEI)
M
To Ignition points question
