69 AIM page j295
Old Jan 27, 2003 | 01:16 PM
dreamn2's Avatar
dreamn2
Default 69 AIM page j295
OK I'm still working on the W.wipers. It shows a black lead coming from the blower motor going to the ww motor. I can't find a place to hook this black wire on my motor. I have a reman. wiper motor. The motor will not work even though it shows 11.8 volts at the terminal. What is the black wire for? Could this be the source of my problems? :banghead:
Old Jan 27, 2003 | 01:56 PM
James's Avatar
James
Default Re: 69 AIM page j295 (dreamn2)
Could it be a ground wire?
Old Jan 27, 2003 | 02:09 PM
Ki m Le's Avatar
Ki m Le
Default Re: 69 AIM page j295 (James)
Yeap, the Black wire is Ground, like James thought.
Old Jan 27, 2003 | 02:15 PM
lbell101's Avatar
lbell101
Yes, that is most likely the source of the problem. There is supposed to be a small 'L' shaped connector on the upper drivers side mount screw. That wire clips to that connector. Just put a round connector on it. Pull that screw and reinstall with the wire connected.
Larry
Old Jan 27, 2003 | 02:16 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
It is a ground, on my non-standard 69 wiper motor the ground is connected to a blade type terminal lug on one of the wiper motor bolts, with a slip on connector. I'm going to insert a picture of my wiper motor, at the top of the motor behind the white washer distribution manifold you'll see a black wire. That's where the lug is attached to the motor case bolt. Make sure you click on the picture so it will display to its full size because it is hard to see.
Old Jan 27, 2003 | 02:51 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: 69 AIM page j295 (Smokehouse69)
yep red is always hot/positive, black is always ground. unless you have a british car :lol:
Old Jan 27, 2003 | 07:28 PM
dreamn2's Avatar
dreamn2
Thanks everyone! I figured it was some sort of ground, just couldn't figure out where it was supposed to plug in. :D
To 69 AIM page j295
