Slightly used engine parts
Old Feb 14, 2024 | 11:29 AM
1980L-82's Avatar
1980L-82
Default Slightly used engine parts
I'm changing my heads, and I'm thinking of replacing my lifters with anti-pump up lifters that have less then 25 hours on them. I replaced them when I was trying to figure out why motor wasn't running right. (misunderstood marks on timing sprocket and was 2 teeth off)
Would it be ok to use these practically new lifters?
Old Feb 14, 2024 | 11:50 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Ain't broke, don't fix it. Run what you got.
Jebby
Old Feb 14, 2024 | 11:55 AM
Sayfoo's Avatar
Sayfoo
You have regular lifters in there now and the car is running ok????
You want to put the previously installed anti lifters back in???
IF the anti's aren't damaged and IF you can get them in the same holes as they came out of, it should be ok.
What advantage did you gain by using the anti's in the first place?
Old Feb 15, 2024 | 04:59 AM
7t9l82's Avatar
7t9l82
They absolutely have to go back in the same lifter boss on the same cam or you will destroy both cam and lifters. Best advice leave it alone.
Old Feb 15, 2024 | 05:48 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'll throw in my 2 cents.
You should never have charged lifters on that cam in the first place. Now that you have, and they are broken in and running. I would NEVER change them again!
Recipe for disaster.
Don't fix what ain't broke!
Old Feb 17, 2024 | 08:19 PM
drwet's Avatar
drwet
Its generally OK to put new lifters on an old cam but not the other way around. Perhaps if the lifters were run on that cam and you can put them back in the same holes they came out of, you might be OK. But I'm inclined to agree you're better off leaving well enough alone.
Old Feb 18, 2024 | 07:41 PM
1980L-82's Avatar
1980L-82
Hoping to avoid valve float. It wasn't the lifters that were bad, as a know it all kept barking in my ear until I changed them. Turned out I had the cam sprocket 3 teeth off. I never used that type with the degree settings all over it and I got confused. And I did get float right around 5800 rpm. These heads got beefer springs also.
Old Feb 18, 2024 | 07:43 PM
1980L-82's Avatar
1980L-82
They are all marked and boxed. I talked to the machinest today, he said as long as they go back in the same hole I should be fine.
Old Feb 18, 2024 | 07:46 PM
1980L-82's Avatar
1980L-82
It is broke, in my eyes. Valve float at 5800 on a cam that is supposed to be good for 7G plus.
Old Feb 19, 2024 | 04:33 AM
4-vettes's Avatar
4-vettes
Valve float isn't your lifters! It's your valve springs!
Old Feb 19, 2024 | 10:01 AM
drwet's Avatar
drwet
Took the words right out of my mouth.
One more thing to consider is ignition. Years ago I had a 4-speed Monza that I was not shy about revving over 6000 rpm. One day I found it would fall flat at 5900. A few days later it was at 5800, then 5700. I talked it over with one of my mentors and he suggested the spark plugs might be failing. Seemed unlikely but it was a lot easier and cheaper than swapping the valve springs. Long story short, he was right. Problem solved.
To Slightly used engine parts
