Quick door striker question
Old Feb 26, 2024 | 08:15 AM
wwiiavfan's Avatar
wwiiavfan
Default Quick door striker question
Is the door striker nut inside the jamb captive, or will it fall down if I remove the striker?
And if it falls down, what’s the best way to get at it?
Old Feb 26, 2024 | 08:55 AM
kanvasman's Avatar
kanvasman
it is captive. It wIll slide around a bit but will not fall off.
Old Feb 26, 2024 | 12:54 PM
wwiiavfan's Avatar
wwiiavfan
Thanks!
Old Feb 26, 2024 | 08:06 PM
wwiiavfan's Avatar
wwiiavfan
Follow up question: which is better, striker with the rotating collar or the solid aftermarket striker? I’m not concerned with originality.
Old Feb 27, 2024 | 08:29 AM
kanvasman's Avatar
kanvasman
I would go with the oem style. But I don”t know how easy they are to find. If the door works properly make sure you scribe a mark around it before removing it just to make it easier to put the new one in
To Quick door striker question
