Sanderson Headers came in...
Old Jan 27, 2003 | 09:05 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Default Sanderson Headers came in...
Going with street rod Sanderson CC-1 headers will definitely not be a performance boost to the engine that is going in, but since I am sticking with the factory sidepipes it seemed like a good solution to tossing the cast iron manifolds in the garbage. A ton of clearance.... better flow pattern.... and routing spark plug wires will be no problem at all on the dart straight plug heads. Definitely nice work they do.
Old Jan 27, 2003 | 09:15 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Sanderson Headers came in... (bgrice)
I have heard from a very reliable source that Sanderson is among the absolute best.
Old Jan 28, 2003 | 12:35 AM
tshort's Avatar
tshort
CI 7-8 Veteran
Cool :cool: Wish I had sidepipes.
Old Jan 28, 2003 | 01:02 AM
Crash Dummy
Default Re: Sanderson Headers came in... (OHSIXX)
OHSIXX...
This is definitely not the way for anyone to go who is looking for a bolt up and run solution. Sanderson headers are designed for special applications to fit the worst scenario clearance applications and I will be at a muffler shop to re-route the extensions from the sidepipes up to these new headers. Most have probably heard of *block-hugger* headers and that's exactly what these are as the collectors are directed inwards towards the block/oil pan. I had Hooker sidepipes on a previous '69 and loved them, but these headers have much more detail put into the fit & grind of the face to the heads.
tshort....
Anything new on your engine? I know you are looking forward to it coming in. It's funny, but the $2500 I spent on the long block is nothing compared to what it takes to really finish a completely new set-up. Thinking you have some components that will go with your new engine... the stock '74 engine was pretty worthless for me to work with, so everything is coming in new. Running behind schedule as you can see. :lol:
Old Jan 28, 2003 | 01:02 PM
groovyjay's Avatar
groovyjay
Looks great, what size are the primary tubes and collectors?
Old Jan 28, 2003 | 02:11 PM
Bamavette74's Avatar
Bamavette74
Default Re: Sanderson Headers came in... (groovyjay)
I have the same pair. Got them because of the side pipe fitment, similar geometry to stock and their matching D-port ports (ZZ4s have the D shaped exhaust ports).
Beautiful headers they make but I had to make a wrench to put one of the spark plugs in tight. No wrench or socket in my arsenal would work (Hun, I need more tools :yesnod: )
I am still in the refurb process, havent heated em up yet but soon will!
Old Jan 28, 2003 | 02:15 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
:cool: :cheers:
Old Jan 28, 2003 | 02:25 PM
Gotta Fix my '76's Avatar
Gotta Fix my '76
Congrats...they look good, and I'm sure will sound great....have fun with the install.
:cheers: :cheers: :smash:
Old Jan 28, 2003 | 03:12 PM
GR8T WYT's Avatar
GR8T WYT
Good decision. I have a pair on my 77. They make an angled reducer that will allow you to direct your pipes straight down instead of toward the block if that would be of any help in hooking up your side pipes. Good luck, Bob :cheers:
To Sanderson Headers came in...
