Heat Riser Location Critical
Old Mar 9, 2024 | 08:07 PM
jpd396's Avatar
jpd396
4th Gear
Default Heat Riser Location Critical
Hello all... upon checking my 72 Stingray 350 /auto trans/with A/C I found the heat riser valve on the driver's side exhaust and it seems to be functioning.
I know it has always been on the passenger side . Curious does it make a difference which side?Thx for any of your thoughts on this. JimD
Old Mar 9, 2024 | 10:43 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Best heat riser is a blocked heat riser.
Old Mar 9, 2024 | 10:48 PM
interpon's Avatar
interpon
Post pictures..
not sure 72 but on mine there is a preheat for intake air. The passenger side had an exhaust flapper forcing heat into engine for faster heat up rate. That one i bypassed.
Old Mar 9, 2024 | 10:55 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
It's all about exhaust gas sealing:
  • Both down-pipes have flared ends to accept sintered ring gaskets.
  • The driver exhaust manifold has a matching 45°ish chamfer for the ring gasket to seal the joint.
  • The passenger exhaust manifold has a flat face that won't mate with the ring gasket.
  • If you examine the heat riser, one face is flat, for a flat triangular gasket, and the other face has a 45° chamfer for the sintered ring gasket.
  • Therefore, the heat riser won't seal well if placed on the driver manifold due to the mismatched gasket sealing surfaces nor will the passenger pipe seal well to the manifold for the same reason.
  • Lastly, the down-pipes are different lengths to accommodate the presence or absence of the riser's 1.5" thickness. Unless the pipes have been modified over stock, they likely don't fit very well.
Old Mar 9, 2024 | 11:39 PM
Bikespace's Avatar
Bikespace
Blocked open perhaps.
The best location for it is removed from the car and in the trash.
Old Mar 10, 2024 | 03:09 AM
ZIOGEO's Avatar
ZIOGEO
To Heat Riser Location Critical
