Low dollar 1980 exhaust solution
Old Mar 14, 2024 | 11:37 PM
Dante Riveras's Avatar
Dante Riveras
Navigator
Default Low dollar 1980 exhaust solution
I found a thread that said that one of the 80’s biggest weaknesses is the cat and the headers. I was thinking about removing the cat, would there be any down side to this? I live in Utah and won’t be dealing with emissions. I was also thinking about changing out the headers. Are there any good manifolds that aren’t restrictive that I could scavenge or are new ones my best bet?
Old Mar 15, 2024 | 12:07 AM
Gale Banks 80''s Avatar
Gale Banks 80'
An all stock 1980 is not that restricted by the single Cat . But that was 40 years ago who knows what shape it is in now. When performance modifications start to happen with the Engine then it also becomes a restriction. There are no other Exhaust Manifolds that are going to make a bid enough difference to be worth the trouble of changing them. The next step would be to go to long tube Headers and a duel Exhaust. To do this on a 1980 You need to change to an aftermarket Crossmember.
Old Mar 15, 2024 | 03:44 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Low dollar exhaust solution, right away I was thinking soup can wrapped around the hole with a couple worm clamps holding it.
I was young once.
As per Your Cat delete question. Look on Ebay for a "Test pipe". Basically replaces Cat with a section of pipe.
didn't think 80's came with any kind of headers. Thought they just had 2 inch manifolds like earlier cars. Guess I don't know much about 80 models.
Old Mar 15, 2024 | 11:48 AM
Dante Riveras
Navigator
I’m new to exhaust, I’m not quite sure the difference of manifolds and headers.
Old Mar 15, 2024 | 01:54 PM
augiedoggy's Avatar
augiedoggy
one is made of pipes and the other is thick cast iron.. The cast iron manifolds typically flow less.
To Low dollar 1980 exhaust solution
