AC Question
Old Mar 16, 2024 | 02:53 PM
pats67copo's Avatar
pats67copo
Default AC Question
My compressor isn't turning on. I know if it's low on freon it won't turn on but is there a fuse or relay or something I can check while I'm waiting to get to a mechanic?
Pat
Old Mar 16, 2024 | 10:00 PM
carriljc's Avatar
carriljc
pats67copo
Which car are are you writing about?
Most vehicles typically should come with some low pressure cutout sensor?
If so, then bypass it and just start the a/c. don't even run the car. the clutch should pick up when you energize and drop out when you deenergize.
Unless I am misunderstanding that is all you are trying to find out.
Old Mar 16, 2024 | 10:24 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Let's guess that your referring to your 71.
Do you own a test light?
Assuming you do, start car and let it idle with the hood open. Switch AC on. On the passengers side inner fender you should see your air-con high pressure line. In about the center of the line, should be a T with a switch in the T. With 2 wires connected to the switch. Take your test light, grounded properly of course. And check for power at these 2 wires at this switch. One wire should be hot with AC turned on.
Both wires will be hot if the switch has enough pressure. This sends power to the compressor clutch.
If you have No power to the low pressure switch, then start looking at fuses, start in the fuse panel. Could be a issue with the switch in the console as well.
But, start at that low pressure switch. If you have power to that, you most likely need Freon. And perhaps you have a leak.
Old Mar 17, 2024 | 05:15 AM
pats67copo's Avatar
pats67copo
Thanks for the information and yes I was referring to the 71
I will check it out thanks again
Pat
To AC Question
