Speaker options for early C3 ?
Old Mar 18, 2024 | 01:31 PM
split63's Avatar
split63
Default Speaker options for early C3 ?
Keeping the original Stereo radio in a 1970.
Anyone know of a speaker rebuild kit?
I see that there is a new replacement pair offered at CC and Zip: https://www.zip-corvette.com/70-77-4...rs-10-ohm.html
However, they are 8 ohm, not 10 ohm.
Anyone with recent experience with a company that rebuilds originals?
Are there any other options?
Old Mar 18, 2024 | 04:05 PM
kanvasman's Avatar
kanvasman
Look at Chrutchfield . They might have some updated speakers that would fit the ohm and size requirements. Top notch company to work with.
Old Mar 18, 2024 | 04:42 PM
ctmccloskey's Avatar
ctmccloskey
I SECOND the suggestion of Crutchfields and they ship FAST and they know what fits and what doesn't.
Old Mar 18, 2024 | 06:04 PM
Mooser's Avatar
Mooser
You will probably get away with a set of 4x6 plates that are 8-ohms as long as you're not cranking it for long periods of time. You could even add a heavy 2 ohm resistor (ceramic or such, 25w+ type of thing) in series to bring it up closer. The speaker impedance isn't linear while the resistor is so the sound will suffer some but the stock radio isn't going to be great anyway so you might not even notice....
Most aftermarket speakers are only 4 ohms and that's not going to work out.
If you're sticking with the stock radio I'd stick with the proper 10 ohm speakers so as to not risk hurting the radio
M
Old Mar 18, 2024 | 06:26 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
Try SM Electrotech. They should have the correct size and resistance speakers for your 70.
www.smelectrotech.com
Old Mar 19, 2024 | 02:49 PM
batman7108@aol.com's Avatar
batman7108@aol.com
Here’s a rundown of the speakers used in my 71.
Old Mar 20, 2024 | 10:45 AM
Tiger Joe's Avatar
Tiger Joe
this is the best solution for stock type speakers
Old Mar 20, 2024 | 10:56 AM
Bikespace's Avatar
Bikespace
I've driven 10s of thousands of miles with nothing more than a Bluetooth speaker and my phone. If originality means more than sound quality, leave the original speakers alone.
Old Mar 20, 2024 | 08:36 PM
split63's Avatar
split63
Anyone know how the C2 speaker was different from the 70-77 speaker? As I compare pictures they seem the same,
Old Mar 20, 2024 | 11:26 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
No. The C1 & C2 ('58-'67) dash speaker is a single 6"x9", while the C3 speakers are a pair of 4"x6".
Old Mar 23, 2024 | 07:23 AM
Quicksilver78's Avatar
Quicksilver78
https://youtu.be/XrX-nXH2ZY4?si=7OoMmCuJFh6v38qC
Thats a great setup and awesome ride.
Old Mar 27, 2024 | 07:53 PM
split63's Avatar
split63
Keeping the original radio, I have found two options for speakers:
1. AC Delco 16033662. Now discontinued, but reproduced by OER here: https://www.oerparts.com/product/196.../16033662.html
The description claims a square magnet, this is BS....its round like the pictures show. This is a new 6x4 10-ohm speaker.
2. speakerex.com has a rebuild kit that is not listed on their site for unknown reasons. You must contact them to order.
4X6” DELCO RK
W46509.01 (4X6” Outside Diameter) (.625 Deep) (.750” Voice Coil Opening) Smooth, All Paper, Cone
VC2195-8 (.875” Inside Diameter) (.750” Form Height) (.250” Wind Width) 9 Ohms, Voice Coil
CS2188-C (2.188” Outside Diameter) (.875” Voice Coil Opening) (.219” Cup Height) Cup Spider
DCP1100 (1.100” Outside Diameter) Paper Dome, Lip Down, Dust Cap
Has anyone tried this rebuild kit?
Old Mar 27, 2024 | 09:06 PM
Newbomb2469's Avatar
Newbomb2469
https://www.crutchfield.com/p_20646C...64.html?tp=105
https://www.crutchfield.com/p_206DSC...04.html?tp=105
Has anyone used these speakers and if so, how did you like them?
Crutchfield states they will fit a 75 under the dash as a direct replacement
Old Mar 27, 2024 | 11:02 PM
barkingrats
This is option 3:
https://www.smelectrotech.com/product/4-x-6-oval-high-performance-single
To Speaker options for early C3 ?
