Super T-10 Sealing Questions
Old Mar 19, 2024 | 02:17 PM
OrangeC3ButImAnAggie's Avatar
Default Super T-10 Sealing Questions
1974 L-82 4-speed (Super T-10) Coupe. I'm currently buying a bunch of parts to replace my clutch and do some other overdue tasks while I'm in there. My question is:
  1. Does the super T-10's side cover (with the two shift shafts) seal to the transmission body with RTV or with a gasket from the factory? And what would you suggest I replace it with.
  2. One bolt is missing from the side cover. I know it is a 5/16-18 thread, as I verified the threads from the missing hole are sound. What length are these bolts and where can I find "correct" ones?
Thanks!
Old Mar 19, 2024 | 05:13 PM
interpon's Avatar
interpon
Thanks!
gasket.. maybe pull one bolt out to measure..
https://www.corvetteforum.com/forums...ispreloading=1
Old Mar 21, 2024 | 05:22 PM
So gasket only? or gasket + rtv?
Old Mar 21, 2024 | 08:43 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Shouldn't need RTV if surfaces are clean and flat. The factory never put RTV on it.
Old Mar 21, 2024 | 09:01 PM
Great, thanks!
Old Mar 22, 2024 | 04:51 PM
GTR1999's Avatar
GTR1999
I always put a skim coat on them. Look on Youtube Pauls used Loctite sealant on them.
Old Apr 19, 2024 | 06:50 PM
Update:
I found a pre-cut paper gasket on eBay, put a skim coat of RTV on it, sealed it up, no leaks at all. Also changed the shift shaft seals. The nine side cover bolts are 5/16-18 and 3/4" long. I ordered those from McMaster Carr. Turns out I was missing 3 bolts from my side cover!
To Super T-10 Sealing Questions
