chrome rims for 68
Old Apr 3, 2024 | 11:27 AM
68 beginner's Avatar
68 beginner
Default chrome rims for 68
can rims with 4.5 backspace fit on 68
Old Apr 3, 2024 | 11:49 AM
LT1M21Vette's Avatar
LT1M21Vette
What is the stock backspace?
Old Apr 3, 2024 | 01:51 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
you will hit the front frame when steering lock to lock. Even a stock corvette 8 inch wheel will hit. the 68 was designed for 7 inch rims
Old Apr 3, 2024 | 04:56 PM
ctmccloskey's Avatar
ctmccloskey
You are absolutely right "AGAIN" as the 1968 Corvette came with 7" rims and any 8" rim could rub your frame Good call there Rescue Rogers!
When I bought my C3 it had two 7" rims on the back and two 8" rims on the front. I ended up buying a set of new 8" rims as I want as much rubber as I can get on the road. The car sure handles better with four rims that match. I want to switch to a 18" or 20" tire if I could afford to. What are you using on your Corvette there RR?
Old Apr 3, 2024 | 06:34 PM
68 beginner
stock backspace is 4 inchs
Old Apr 4, 2024 | 09:55 AM
Rescue Rogers
I went from a c3 8" Rally to 17"x 8 inch and now back tob15 inch.....the 8 inch rally was about an 1/8th inch from rubbing the e brake bracket on the trailing arms...way too close. The fronts rubbed the frame smooth at thevrear of the front wheel well. Then i went to the 17s and there was a ton of room from the e brake mount but the spring bolt looked closer....never had any cut tires though....fronts still rubbed.
The 15s I have now are too little back space and are really wide so the hit the back of the front fender.....but they look cool
To chrome rims for 68
