Best Header Gaskets?
Old Apr 4, 2024 | 07:57 PM
OldCarBum's Avatar
OldCarBum
Default Best Header Gaskets?
Who makes the best header gasket sets these days?
I see them offered in copper, aluminum, ultra seal, marine, metal core and the good old standby laminate ones I’ve always used.
Too many choices these days.
Summit has over ten pages of choices for Chevy big block.
Old Apr 4, 2024 | 08:18 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
The best?
MLS like Cometic
Link
Old Apr 4, 2024 | 09:34 PM
Mooser's Avatar
Mooser
I've had a set of Percy's ''Dead Soft'' Header Gaskets on for a few years now and have never had any issues. Nice thing is they survive being taken off and put back on again... Yes you need to thermal cycle them and re-torque but I normally would do that anyway
I've also got a pair of taylor/percy carbon gaskets up on the shelf that were going to be my next try if the dead soft blew out, which they didn't, but I just looked and it seem they don't sell those anymore... not sure what to read into that, they were supposed to be the new revolution in gaskets...
M
Old Apr 5, 2024 | 12:17 AM
gkull's Avatar
gkull
Felpro blue steel. You can even re use them. Never a blow out or burn through even with glowing header pipes like you see on extended dyno runs
Old Apr 5, 2024 | 12:42 AM
ddawson's Avatar
ddawson
I used these.
https://www.summitracing.com/parts/RFL-2013
Old Apr 5, 2024 | 06:47 AM
roscobbc's Avatar
roscobbc
M
I've a set of those too - have used other brands/types before including solid copper (annealed before re-using) and the Percy's multi-layer alluminium gaskets have been the best and lasted the longest so far!
Old Apr 5, 2024 | 07:34 AM
cottoneg's Avatar
cottoneg
I spoke to a Summit Technical specialist for the same reason. He recommended Patriot Seal-4-Good Header Gaskets 66012. Are they the best? I have no idea.
Looks like this will be any oil thread where everyone has an opinion.
Old Apr 5, 2024 | 07:58 AM
pspicci's Avatar
pspicci
Remflex
Pat
Old Apr 5, 2024 | 09:28 AM
Z0Tex's Avatar
Z0Tex
Remflex. A little $pendy, but easily reuseable.
Old Apr 5, 2024 | 10:25 AM
ctmccloskey's Avatar
ctmccloskey
I have been using the Soft Copper exhaust gaskets for over 2 decades and they have NEVER leaked or needed to be re-tightened. I would try the aluminum if they are cheaper as long as it is the soft type of gasket. The copper gaskets attach a set of Hedmann Headers and they have never been off the car since the day I installed them.
Old Apr 5, 2024 | 01:10 PM
OldCarBum's Avatar
OldCarBum
Are the Percy’s now Patriot Seal-4-Good gaskets?
Summit carriers the Patriots and I can only find the Percy’s available on Amazon.
Old Apr 5, 2024 | 01:13 PM
OldCarBum's Avatar
OldCarBum
I looked up the newer copper gaskets and they have great reviews, however the only bad reviews were from guys running the new Hedmans with the raised and machined flanges, like mine.
They reported leaks until swapping the copper for aluminum.
Old Apr 5, 2024 | 01:50 PM
OldCarBum's Avatar
OldCarBum
New question,
I have 2” primary tubes on my new Hedman headers.
The inside diameter of the round tubing at the flange measures approximately 1.875”
Should I buy the header gaskets with the 1.875 diameter round opening or go with a 2.1” diameter round opening?
Old Apr 5, 2024 | 05:46 PM
Mooser's Avatar
Mooser
Percy was bought by Taylor (the wire guys) and then Holley seems to have bought Taylor and limited the line to basically ignition wires.
Seal-4-Good was trade marked so I'd say Patriot bought the rights now and pertronix owns patriot...
M
Old Apr 5, 2024 | 05:48 PM
Mooser's Avatar
Mooser
New question,
The inside diameter of the round tubing at the flange measures approximately 1.845”
Should I buy the header gaskets with the 1.875 diameter round opening or go with a 2.0” diameter round opening?
Try to "port match" sort of, if there's a gap, the exhaust gas will try to squeeze into that opening and the chance of blowing it out goes up
M
Old Apr 5, 2024 | 07:38 PM
OldCarBum's Avatar
OldCarBum
Thanks Mooser,
I’m thinking the 1.875” round port gaskets will be the ticket.
Old Apr 6, 2024 | 07:22 AM
69ttop502's Avatar
69ttop502
The guy who built my headers said don't bother with gaskets and just recommends silicon sealer. Been doing it that way and never a leak or problem.
To Best Header Gaskets?
Old Apr 6, 2024 | 07:49 AM
HeadsU.P.'s Avatar
HeadsU.P.
That is the same mentality that Intake Gaskets don't need sealant.
Bad idea in my opinion
The header flange is subject to extreme temperature swings.
One moment, depending on where you live, it could be well below zero.
Next moment the flange could be over 400 degrees.
Expand / Contract. Expand / Contract.
Fiber type gaskets and sealants do not expand / contract.
Copper & Aluminum do.
Old Apr 6, 2024 | 10:34 AM
gkull's Avatar
gkull
Your gasket should match the flange pipe. Hopefully your headers primary side is bigger than your head port. I've actually ground the inside of the headers before to match the heads. My two vette motors are .600 raised exhaust ports and kind of D shaped. So I bought the FelPro blue steel with the header flange round port in mind. The D shaped head port has some anti reversion good charateristickes. Over the years I tried all kinds of gaskets because engines would come and go on an annual basis. copper was kind of a one shot deal. They worked good untill you pulled the headers. The extreem heat hardened the copper. When you put an extended load on the motor temps of 1300+ degrees are common. I tried Energy Suspension red poly motor mounts many years ago before solids. The driver side broke and they melted because of header heat and were a PITA to remove because they had blobbed over the 3 motor side bolts. It took a die grinder and hammer chisel to remove the red crap.
Old Apr 6, 2024 | 12:22 PM
OldCarBum's Avatar
OldCarBum
During my research with different headers, there are several header manufacturers who require that no gasket be used.
Ive used Sanderson headers over the years on boats and cars.
Their headers flanges are raised then machined perfectly flat, 3/8” thick, do not require gaskets and they even state you will have exhaust leaks if gaskets are used.
Ive never had an exhaust leak, or had to replace a gasket on any of their headers.
The main reason for using gaskets on most headers is they use thin flanges, they warp, their welds are crap, and they do a poor job of finishing the flange to head surface.
On Monday I’m taking my modified Hedman long tube headers to Sanderson’s to be ceramic coated.
I plan to try and talk them into building me a set of long tube headers for my big block using my Hedman’s as a template.
If they will, I’ll have them do so, because they manufacture the best quality headers on the market today.
Unfortunately they don’t make long tube headers for big block Corvettes, but they will build custom headers.
