Where does this spacer go?
Old Apr 9, 2024 | 01:49 PM
laurieonthego's Avatar
laurieonthego
Default Where does this spacer go?
Hi All,
It’s me again…I am trying to identify where this spacer goes. I believe it is utilized in mounting the Generator/alternator—near the bracket?!
I just love all the expertise and love on this site. If you recognize it, please educate me. This spacer is SOLID, not hollow in the middle!
Old Apr 9, 2024 | 04:00 PM
J.Abbott's Avatar
J.Abbott
Looks like a cylinder head pin.
Old Apr 9, 2024 | 04:02 PM
J.Abbott's Avatar
J.Abbott
looks like a cylinder head locating pin or the drive pin out of a camshaft.
Old Apr 9, 2024 | 05:00 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Where did you find this....a one inch pin is pretty long for the above suggestions
Old Apr 9, 2024 | 05:49 PM
laurieonthego
It was in my one of my boxes of parts for reassembly (74 BB) - in what I think could have been an incorrectly labeled bag in with my alternator/brackets and bolts. At first I thought it was some sort of spacer but is solid and almost 1" long which is longer then the cylinder head dowel pins I am seeing online. Also, when these parts were all bagged and labeled the motor had not been touched for disassembly other than the pan being dropped for a new oil pump, screen, pick-up tube and rear main seal. So, still trying to figure out what it could be. Thanks for your help!
Old Apr 9, 2024 | 07:34 PM
Rescue Rogers
could be the locating pin for the oil pump
Old Apr 11, 2024 | 07:37 AM
stingr69's Avatar
stingr69
Locating pin for throttle cable bracket on back of Quadrajet?
Old Apr 11, 2024 | 07:46 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Isn’t that one of the pins from the bellhousing? Hard to tell the width.
Old Apr 11, 2024 | 12:57 PM
ctmccloskey's Avatar
ctmccloskey
The scale of that part leads me to think it might not have anything to do with a Corvette. Most of the Dowels I have run across are smaller in diameter and shorter in length just as suggested by Rescue Rogers a couple lines above.
The darker colored ends might be the only part that sticks out or it is pressed into something. Being solid should point you in the right direction as most pieces like that which I am familiar with a tube through the center making it a "Spacer". The dowel pins used on a diesel I had back in college were big similar to what you have.
I am afraid to say that in all my years of Corvette tinkering I have not seen anything like that part, I wish you luck!
Old Apr 11, 2024 | 02:12 PM
Del96lt1's Avatar
Del96lt1
Water pump guide pin ????
Old Apr 11, 2024 | 03:51 PM
HeadsU.P.'s Avatar
HeadsU.P.
What diameter is a flywheel pin?
As I recall bellhousing dowels had a chamfer on the end to help self-center?
It goes to your 12 horse, 32 inch cut riding lawn mower sitting in the corner.
Old Apr 14, 2024 | 10:25 AM
J.Abbott's Avatar
J.Abbott
It doesn't go anywhere on the alt setup and it is too small in diameter for the bellhousing. Still thinking a cylinder head or cam but the cam is smaller diameter than a cylinder head. I can't remember if the one is block is a 3/4" or 1" though. They are not too short but it has been along time since I have had one out.
Old Apr 14, 2024 | 12:09 PM
laurieonthego
Lol!!! I am so glad you reminded meez!!!!!
Old Apr 14, 2024 | 12:12 PM
laurieonthego
Thank you so much! We still have not figured it out...definitely not the ALT or WATER PUMP. EEKS!
Old Apr 14, 2024 | 12:21 PM
laurieonthego
Default Thank you so much! The mystery continues...
Well, so far...I'm thinking you are correct! There is a wealth of knowledge and information on this site. I AM VERY GRATEFUL FOR THE SUPPORT AND EDUCATION I receive on this site! None of us have come up with this being a part for our 74 BB 454...I will share with everyone if we ever hit the jackpot on the answer
Thanks all for taking the time and interest in helping me. You ROCK!!!
Laurie, RN
Just here in Fountain Hills enjoying working on cars as much as I do on peeps
To Where does this spacer go?
