Replacing Cylinder Heads
Old Apr 15, 2024 | 10:58 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Replacing Cylinder Heads
Do you have to take the engine out of the car in order to install these heads?
Old Apr 15, 2024 | 11:26 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
No, you do not, just unbolt and set aside the accessories. Now, this will be a great time to replace your timing chain and timing gears. But you will have to drop the pan.
Whose heads are those? What you have to understand is that the Chinese can and do cast pretty good heads, however, the valve train is often very suspect. The .525 max lift kind of verifies this. Can you get those heads bare? What intake & carb are you going to use?
Old Apr 16, 2024 | 07:51 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Absolutely no issues putting heads on a C3 with engine in place.
Why those heads?
Make certain you measure up pushrod length.
Guide plates?
Who makes these?
Who's valves? Springs? Retainers?
200cc intake runners? What are you building?
Old Apr 16, 2024 | 10:53 AM
ZIOGEO's Avatar
ZIOGEO
I just replaced the heads on my 73 last January. I went with the Edelbrock e-street heads. It was tight with the AC but engine remained in the car.
Old Apr 16, 2024 | 06:39 PM
HeadsU.P.'s Avatar
HeadsU.P.
I don't know where you got that idea VetteGuy but its a pretty easy straight forward project.
And putting the front end up on ramps will save your back.
If you do go this route from cast iron to aluminum heads, you will need specialized additional parts.
ARP Head Bolt kit.
Head gasket compatible for mating aluminum to iron.
Pushrod length checker.
Longer pushrods compatible with guide plates.
Usually longer reach sparkplugs.
Old Apr 17, 2024 | 07:00 AM
4-vettes's Avatar
4-vettes
Well, totally different spark plugs. Most factory iron heads use a tapper seat plug. While aluminium heads usually use a gasketed type plug. And yes, reach will vary.
Old Apr 17, 2024 | 07:03 AM
4-vettes's Avatar
4-vettes
Just had a look at your profile. Looks like you already have a replacement engine. Much better than stock.
Why on earth would you want to replace the heads on a already good engine?
Especially with these heads?
Color me confused.
To Replacing Cylinder Heads
