Harmonic balancer
Old Apr 21, 2024 | 09:10 AM
stingr69's Avatar
stingr69
The crank keyway on the SBC is at 45 degrees and points at the drivers side block deck when the crank is at #1 and #6 top dead center position. The dampers and timing tabs are a matched set and they are moved by GM to work best with the chassis they were intended to go into. Most '69 and up passenger cars share a common balancer tab combination. There are some truck applications etc that use different locations based on visibility during service.
#1 cylinder is drivers side front for SBC. Not passenger side as you might find on some other brand.
Edit - Sorry for the extra post. I was typing slowly. Carry on!
