I have 1970 with its original 454, AC and a 4-speed. The car has the thin expansion tank with a radiator cap, due to the car having AC. However, the radiator that is in the car (probably not original) also has a radiator cap. Would I just put AC-15 caps on both? Will this combo of two radiator caps cause any issues?
Nope! My ‘71 350 had an expansion tank and a copper/brass replacement radiator. Two 15lb caps; no problem. Except I did have a NAPA cap fall apart after a year. Just leaked from that cap, which was annoying.
I have 2 caps on my 68.
1 on the expansion tank (functional) and one on the radiator (just a cap).
I gutted the cap on the radiator so it is really just a cap and does NOT perform any pressure release function. Been like that for 20+ years (I'd have to check). My radiator is an aluminum radiator from summit because it was the biggest relatively inexpensive one I could squeeze into the space on my 68. That original 68 Radiator was a little bitty thing. I figured if I ruined it then it would not be an expensive mistake...but it has worked wonderfully.
You are right in thinking the radiator shouldn't have a cap. Big blocks ('69-'72) had an expansion tank did so did not have a standard radiator neck. (not sure about '73 & '74 bb) The '66-'68 427s did not have expansion tanks so had the cap on the radiator.
