7042203 measurements needed
Old May 10, 2024 | 11:27 AM
ERICK's Avatar
ERICK
Default 7042203 measurements needed
Before making any modification to the carburetor I got(1972 350CI truck carb (704 2210 ), I would like to compare the measurements
for that truck carb with the ones for a same year vette carb (7042203 ) because I need a base line to mimic the vette measurements
I only found jet and needle size on the net. I hope both carbs have the same casting! If it was easy to find a quadrajet here in France, I wouldn't have made that choice...
So I need measurements for:
Main air bleed, air horn and float bowl
idle tube
idle down chanel restriction
upper idle air bleeds
lower idle air bleeds
iddle bypass airholes
iddle needle holes
Old May 10, 2024 | 11:43 AM
MelWff's Avatar
MelWff
idle tube
iddle needle holes
Send an email to Lars Grimsrud at v8fastcars@msn.com.
