75 with no spark!!!!!!
Forgot to mention: * Auto trans * has HEI * hasn't run for God knows how long * mostly original *Also extremely good point; I definitely don't fully trust new parts.
Stock HEI?
Manual/Auto?
Modified or stock?
Have you or anyone changed any electrical parts since it last ran?
Have you checked for 12v at the BAT terminal on the HEI cap?
Good place to start is your ground wires. Make sure the connection points are all clean and tight.
Also, just because you installed a new Chineseium electrical part does not mean it works!!
I believe all the safety (start) switches such as neutral, clutch depressed, etc would not allow a crank mode. You have crank / no start mode.
You changed the coil. Did you find and connect a black small gauge wire to one corner of the coil frame?
(Some years did not have a wire but a GRD bracket instead) Regardless, the coil has to be grounded.
Under the coil is a rubber washer / insulator. Under that is a spring type bushing. That bushing must protrude through the dizzy cap and make contact with the rotor.
With the coil dust cover off, you can verify all color-coded wires are in the correct spot in the cap.
Always the "slim" possibility that a wire is not on the starter solenoid that supplies juice.
Ground wire correct?
Also i looked at the starter wiring and its definitely a rats nest, surprised it cranks so hard. I will start there tomorrow.
Is it just me or just the photo, but the yellow and the red wires almost look melted coming out of the coil.
H-m-m-m-m-m-. ?????
Strange place for the number one plug-wire, but it works for you and that works too.
Just a note here.
Those coil frames are coated with a paint / sealant that keeps them from rusting. Does the paint hinder a excellent contact for the GRD wire? IDK
But I do advise to remove the GRD wires and wire brush to bare metal on that one corner.
If you don't have power at the batt terminal then that's the place to start.
I would break this into two parts - Testing the wiring to the distributor and testing the distributor.
Testing wiring - continue with your investigation checking for 12 volts at the wire that connects to the distributor with the ignition in run and shifter in park and or neutral (doubting neutral safety switch as the starter works) I don't have a wiring diagram for your car but one should be available online. Do all the other car electrics seem to have power?
Testing the distributor - build up a test wire with a female crimp type connector on some 10 gauge wire (12 gauge should be ok for a test). The female crimp connector would connect to the batt terminal on the HEI coil. make the test wire long enough to get to battery or jumper cables that can connect to battery. This test wire will bypass the ignition switch. You can put a switch in the wire. With ignition in the run position replace the wire that connects to the coil with your test wire and turn car over looking for a a spark. If spark then check car wiring further. If no spark check distributor further.
This is the **** I get to work with. All the wiring in the whole thing is like this. Honesty not the worst but it's still like an adult mind ******* puzzle. I crank it with a pick or screwdriver. Oddly enough I got the headlights(of course they dont flip by themselves) and interior lights working. I was able to clear out what ever nested (literally) in the starter wiring. Maybe those ******* chewed something and it will be an easy fix. Yes I am aware I just screwed myself by saying that. In any case I am going to tackle that tomorrow, I am a single father and it's amazing to get any time to work on it. Thanks for all your help.
Allright, first of all as always thanks to all the people that are trying to help me. @Peterbuilt that was a great picture those help me more that the regular wiring diagrams. So I got power to the battery terminal and no spark. First i am going to put the old coil back on and see if it sparks. If not I am guessing the pickup coil or both coils are bad. Plus I also gotta find the break in continuity going to the battery terminal on the cap. One odd thing I noticed was that as soon as I jumped the battery terminals (cap bat terminal and regular battery terminals) the door ajar light started work when I opened the door. Had never seen that light on before.
