which way to go?
Old Jan 30, 2003 | 11:37 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default which way to go?
If I wanted to upgrade from the Stock '82 setup?
Old Jan 31, 2003 | 01:02 AM
NHvette's Avatar
NHvette
Default Re: which way to go? (Markm10431)
I've seen LT1 setups from Z28s with OD trannys for around $2000 used.
Not a bad upgrade at all. The crossfire can be OK - but never reach the
potential of a newer TPI.
:seeya
Old Jan 31, 2003 | 05:39 AM
Mystery Machine's Avatar
Mystery Machine
I voted retro, only because I think it would be easier to work on. As far as fuel economy go TPI. As far as performance, both retro and TPI have their high and low points...IMO. :thumbs:
Old Jan 31, 2003 | 07:36 AM
Corey_68's Avatar
Corey_68
Default Re: which way to go? (Mystery Machine)
I'd go carb, MUCH cheaper and easier to work ( no sensors to worry about). I thought about going FI but then I couldn't run side pipes so that ended that. :lol:
Old Jan 31, 2003 | 07:43 AM
RMVette's Avatar
RMVette
Do you have a yearly inspection for emissions? If so, I'd go TPI. :cheers:
Old Jan 31, 2003 | 02:33 PM
Markm10431's Avatar
Markm10431
Parrothead
Default Re: which way to go? (RMVette)
that's a great question. right now, Florida is inspection free. Who knows when that can change (as soon as a demo gets in the gov mansion, probably)
and there is the slight chance of me relocating to california
Old Jan 31, 2003 | 03:21 PM
page62's Avatar
page62
If you're relocating to Kalifornia, DON'T TOUCH IT!
Old Jan 31, 2003 | 04:12 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: which way to go? (page62)
$5,000 and a Summit Racing catalog
Old Jan 31, 2003 | 06:10 PM
Carl in LA's Avatar
Carl in LA
Default Re: which way to go? (Paul 75 L82)
I voted retro... the more I look at cars with FI that also look so complicated with hoses and wires running everywhere - the more I like the pre smog pump cars!
Since I'm on the subject - Why do some modern cars bury the engine under plastic covers (vette included)?
I do agree with folks above that smog rules could really ruin your day if make the retro choice.
Old Feb 1, 2003 | 12:19 AM
Markm10431's Avatar
Markm10431
Parrothead
unfortunately, I don't think ai rebuild to original spec will pass Ca inspections
To which way to go?
