Differential rebuild
Old May 26, 2024 | 08:21 AM
Jackk's Avatar
Jackk
Default Differential rebuild
Can anyone recommend a good differential shop in the Toronto area?
Old May 26, 2024 | 11:15 AM
69L88's Avatar
69L88
What’s wrong with yours?
Old May 27, 2024 | 06:54 AM
piste's Avatar
piste
Banned Scam/Spammer
Gary Ramadei. Yes he is in CT but given he recently did a diff for a guy in Prague I would say he is in Toronto area!
Old May 27, 2024 | 03:09 PM
60 SHARK's Avatar
60 SHARK
You won't be disappointed 👍 It will be worthwhile to call him first.👈
Old May 28, 2024 | 01:45 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Old May 28, 2024 | 06:01 PM
OMF's Avatar
OMF
You should check this out, Maybe someone local to you has some experience with them.
https://corvetteclubofontario.com/
Old May 28, 2024 | 06:28 PM
Ahern70's Avatar
Ahern70
5th Gear
I could use one as well for a 1980 Dana 44, located in Michigan.
Old May 28, 2024 | 08:18 PM
Jackk's Avatar
Jackk
Thanks, it's worth a shot.
Old May 28, 2024 | 08:24 PM
Jackk's Avatar
Jackk
107000 miles on it. leaking oil from the pinion seal. 100 thou. end play on both side yokes. Side yokes are worn right down to C clips inside
. Gears look ok.
Old May 29, 2024 | 07:15 AM
Jackk's Avatar
Jackk
It looks like it's going to be a challenge to get the axles out as the end inside is worn down to the c clip and flared out
on both sides.
Old May 29, 2024 | 08:26 AM
69L88's Avatar
69L88
Because the axles are softer than the spider, a slide hammer will do the trick without issue.
Old May 29, 2024 | 10:52 AM
Jackk's Avatar
Jackk
It just keeps getting more challenging. The bolt/pin that holds the center pin in is broken. The threaded part came out but the pin stayed in. Geez
Old May 29, 2024 | 11:02 AM
interpon's Avatar
interpon
was where you are leaking/ end play
link to mine with great advice and hand holding i got might save you some hassle.. still leak free and working perfect
https://www.corvetteforum.com/forums...ispreloading=1
Old May 29, 2024 | 11:48 AM
69L88's Avatar
69L88
What “center pin” are you referring to?
Old May 29, 2024 | 11:54 AM
Jackk's Avatar
Jackk
I'm referring to the pin the the spider gears turn on inside the diff. The bolt that secures it in place is broken. Just the threaded part came out leaving the pin if you know what I mean.
Old May 29, 2024 | 12:10 PM
Jackk's Avatar
Jackk
Its the bolt that secures the pin inside the diff that hold the spider gears. The bolt is broken leaving the end of it still holding the center pin in diff in place
Old May 29, 2024 | 04:43 PM
Jackk's Avatar
Jackk
Ok got that sorted out. Does the crown gear have to come off to remove the spider gear and clutch pack. Doesn't see to be enough room
To Differential rebuild
Old May 29, 2024 | 06:52 PM
69L88's Avatar
69L88
You need to turn the posi unit to allow the spider gears to move off their perches to be removed through the opening. Be sure to keep outward pressure on both side gears while you turn them or the gears will lock up. It is indeed a very tight envelope to work in.
Old May 29, 2024 | 07:08 PM
Jackk's Avatar
Jackk
I have done as you suggest and removed the small spiders but I cannot get the bigger spiders with the clutch pack on to come out. The gear binds on the crown and carrier when you try to remove it.
Old May 29, 2024 | 09:24 PM
69L88's Avatar
69L88
Those ride on roller bearings and should slide easily inward as there should be nothing in the way. There is a pair of “keepers” on each side that hold the stationary clutch plates and the ends are visible through a pair of quarter sized holes in the casting. You can try a little “persuasion” by tapping on those keepers to see if you can get the assembly to move.
