Wiper Issue
Old May 28, 2024 | 09:53 PM
Newbomb2469's Avatar
Newbomb2469
Default Wiper Issue
If the windshield wipers along with the windshield wash are not working, is it most likely the switch?
Old May 28, 2024 | 09:58 PM
gjohnson's Avatar
gjohnson
Might have come unplugged
Old May 28, 2024 | 10:14 PM
Mooser's Avatar
Mooser
There should be a fuse for the wipers, I'd start there
M
Old May 28, 2024 | 10:24 PM
Newbomb2469
M
Replaced the fuse, wasn’t easy to see if it was blown, so put a new fuse in, but the wipers didn’t work and the fuse did not blow.
Old May 28, 2024 | 10:38 PM
Mooser's Avatar
Mooser
If the fuse is ok, there should be power to the middle of the 3 wires on the wiper motor plug with the key in the run position regardless of the wiper switch.
M
Old May 29, 2024 | 10:09 AM
robertea's Avatar
robertea
The switch only supplies ground to the motor. Here is a drawing that might help. It was made for a 69 so will be slightly different than what you have, but the motor itself is basically the same for a number of years.
You won't have the "limit switch" since your car does not have the cover that goes over the wiper assembly, but as far as I know the rest of the circuit should be the same. The entire wiper circuit always seems to confuse all of us.
Old May 29, 2024 | 01:50 PM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
Old May 31, 2024 | 07:23 PM
Newbomb2469
Turned out it was a loose ground wire…always check the simple things first.
To Wiper Issue
