C3 electrical
Old May 29, 2024 | 05:19 PM
jjford129@icloud.com's Avatar
Default C3 electrical
I have a 1982 corvette, and the front right turn signal indicator wont flash. Its the one above the white parking light, and it turns on when i have the lights on. It just wont flash with the signal. Any ideas what could be wrong?
Old May 29, 2024 | 07:22 PM
kanvasman's Avatar
kanvasman
Have you checked to see if there is current to the bulb? If there is then maybe its the bulb. Switch it with the one on the other side, if it works, then it's not the bulb. Maybe it's a ground that isn't making a good connection. WHen you take the bulb out look inside and see if there is any corrosion on the contacts. This is a good exercise for you to diagnose what should be an easy fix, you just have to be methodical and go down a list of possibilities one at a time. It would also be a good reason to get a shop manual or a wiring diagram for your car. Lots of these little gremlins will be popping up. Tell us what you find. And welcome to the club
Old May 29, 2024 | 11:14 PM
Bikespace's Avatar
Bikespace
Do you have any LED bulbs in the front of the car?
Old May 31, 2024 | 06:42 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
82's are an entirely different animal than other C3's.
does it have a duel filament bulb? Is it wired like earlier C3's.
I just don't know. It's an 82.
Old May 31, 2024 | 12:22 PM
i do have LED bulbs in the parking lights, but those work just fine. I have halogens in the turn signals still.
Old May 31, 2024 | 12:24 PM
i have checked fuses, connections and contacts, like i said; it does recieve power when the park lights are on however it just doesnt flash with the turn signal.
Old May 31, 2024 | 12:40 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
is the bulb installed correctly. it may be installed 180* off
Old May 31, 2024 | 12:41 PM
Rescue Rogers
If its in correctly use a voltage tester to see of the voltage is flashing...you can test it against the results of a good socket for reference
Old May 31, 2024 | 01:34 PM
ZIOGEO's Avatar
ZIOGEO
Did you just install the LED's? If so, your going to need to update the flasher to an electronic one. If you already updated the flasher to an electronic one then the flasher is wired backwards and you will need to make a pig tail to connect it correctly to cross the wires into the socket. Electronic flashers are polarized where the OEM bi-metal coil flasher is not. My money is on the flasher wired backwards which is why the bulbs light but dont blink
Old May 31, 2024 | 01:41 PM
Bikespace's Avatar
Bikespace
The front side marker lights add an additional complication with LEDs, but here is what I learned while converting all of my bulbs to LEDs. As @ZIOGEO pointed out, you need a specific LED-capable flasher at a minimum. 100% LEDs are possible, though.
https://www.corvetteforum.com/forums...s-learned.html
Old May 31, 2024 | 02:42 PM
Rescue Rogers
he does not have LED bulbs in his turn signals......
Old May 31, 2024 | 02:52 PM
Bikespace's Avatar
Bikespace
Yes he does, assuming the "parking lights" are the front facing lights bellow the headlights. In an 80-82, they are 1157s. I use white/amber switchbacks (which look green in the video), and not all 1157 LEDs even work. Cheap ones do not, so that could be the issue, but I'd start with a grounded, LED capable flasher.
Old May 31, 2024 | 03:23 PM
Rescue Rogers
who told you that he did? Either he has a different set up than you think , he is wrong on the year, or he doesnt know that his turn signals are parking lights too.....
Old May 31, 2024 | 03:30 PM
Bikespace's Avatar
Bikespace
The OP stated (and you quoted), that he has LEDs in his parking lights. In an 82, all parking lights flash (except the rear side marker lights). So they are all "turn signals". Perhaps the OP has never seen this behavior, and didn't know. At the 28 second mark in my video, I turn my parking lights on, so you can see the difference in behavior. With the proper LED flashers (and Blinker Genies), 100% LED bulbs work just fine, including the white cornering lamps (80-82 only), and parking lights acting as turn signals.
We can argue semantics if you want, but the OP needs an LED-capable flasher unit (two, actually, likely at least one with a swapped base). And he may need better 1157 bulbs in the "parking lights".
It's all in the link I posted!
Old May 31, 2024 | 03:44 PM
Rescue Rogers
Maybe you should post a wiring schematic for him so he can see what you are talking about
Old May 31, 2024 | 03:53 PM
Bikespace's Avatar
Bikespace
I did. Three years ago. But he doesn't need this. The Blinker Genies are only needed if the front side marker lights are replaced with LEDs.
@Richard454 also posted some wiring diagrams in this thread.
https://www.corvetteforum.com/forums...rn-signal.html
Here is the modified wiring diagram I used. I only cut 3 wires on each side, and the cornering light doesn't really need to be cut, just an extension added to join the grounds of the Blinker Genie and marker lights.
Old Jun 1, 2024 | 05:34 PM
Sorry to cause any confusion, in the video i just uploaded the first shown bulb is the one with the issues, as you can see the park lights come on with the signals, however the yellow flasher on the right side facing forward just doesnt flash. Also, i apoligise for the misunderstanding i was under the impression that the orange lights directly under the headlights were not park lights
To C3 electrical
Old Jun 2, 2024 | 03:50 PM
Bikespace's Avatar
Bikespace
I watched the video three times, but still don't know what is going on. I never saw the lights under the headlights, so I can't say if they are working or not.
The cornering lights (the WHITE lights on the sides) only come on when using the turn signals WITH the parking lights (or headlights) turned ON.
You might just be missing a ground, or have a bulb partially installed somewhere, or who knows.
What happens if you switch back to all halogen lights? Do you have LED flashers installed? Perhaps the side with the hyperflash is the only one with an LED bulb.
Wiring diagrams are here, with GM's terms, so we can all be on the same page. The bulbs under the headlights are both "parking lights" and "directional lights", per GM's naming convention, though they are the same 1157 bulb, with two circuits. Are you sure that's what's installed? Sometimes 1156 (single circuit bulbs) end up installed instead, and sometimes the bayonet mount needs to be cleaned (mine certainly did). You'll see a ground in the diagram on both front corners of the car. If that's missing, other screwy things can happen.
https://wordpress.keystonestatecorve...m/?page_id=118
Old Jun 3, 2024 | 04:37 PM
thank you for the clarification, the bulbs i am talking about are the signals above the CORNERING lights, as shown in the video, i apologize for the confusion
Old Jun 3, 2024 | 04:58 PM
Bikespace's Avatar
Bikespace
Okay. Those are the (front) marker lights, and in 80-82 cars, they do flash with the turn signals. The rear marker lights do not. What are your directional lights (under the headlights) doing while this is happening?
Finally, which bulbs have been replaced with LEDs? If you have more than zero LEDs among your turn signal bulbs, you will need two LED flashers.
