I have an 11-1 c/r 383. Forged eagle rotator. 200cc Dart heads. Good stuff.
I’m bored of the current cam.
I want something really wild. Something angry.
Are you trying to keep the lift the same?
edelbrock torker plus #5002 has more duration and smaller LSA. similar lift.
id consider 1.6 ratio rockers too
You need to go to solid rollers for no rpm limitation. my stroker SBC's are 7500 rpm. Your heads are a limitation. I use a custom billet 236/242 with 112 on my 383 and now a 396. I went for the broadest power curve that is like 4000 rpm wide
I’ve got 1.6 roller rockers. 3.55 gears. Tremec TKO 600RR, Ali flywheel, ATI balancer, msd ignition, All the good stuff.
I was thinking that. Solid roller. I guess I want a meaner idle, actually I should find a cam that tops out around 6700-6800.
According to engine simulation software my peak power is right at 6800 rpm, but it doesn't sharply drop off and I have the rev limiter set to 7500. You could set the rev limiter to 6800 if you wanted to. I use the FAST multispark and sequential rev limiter which has dials for settings. I tried a 242/248 solid roller with my 227 cc race ported heads and tall single plane it wasn't a good street/strip motor because of unresponsive carburation under 2500 rpm. That is why I toned it down 236/242.
I have the 600 .64 od tranny with 4.11 rear end with 22 pound flywheel. Roller cams make more vacuum and low end TQ than flat tappets
The Erson cam list shows the Lobe Centers. Blower motors don't want intake reversion so they use 114 LC. I had my billet custom cams ground on 112 for the highest average power numbers and a broad power band. When you get to 110 LC or less gives you a higher peak TQ and then the engine drops off. The reversion because of overlap give the motor a rowdy idle like a race car for only operating in a narrow rpm range.
Street machines or dual purpose lapping cars need a 4000 rpm wide power band. I can use 5th gear over drive running around town
Most roller cams actually have better manners than any flat tappet...and solid rollers are even better than hyd rollers usually. You can run a more aggressive solid roller and keep manners.
I did a 388" for a buddy with a custom 248* SR on a 107 LSA. That thing is sweet...sounds killer...will go 7K plus anytime and every time he drives it and is amazingly easy to drive even when he had the 3.36 gears in it with the 4 speed. He broke that rear and stuck in 3.70's now. It's a deep/low 11 sec car on plain BFG street radials.
JIM
I concur
The flat tappet in my 383 is a bitch low down. My Dad’s sbc 427 with the Howard’s hyd roller 545” starts and idles smooth, but rips when you get on it.
So the plan is. Take the tko600rr out of the vette and put it in the Camaro (current has .64 Tremec). To see if it solves his whine issue.
If that sorts it the gearbox can stay in the Camaro and I’ll buy a TKX .82 fifth for the vette, at the same time I’ll change the ali flywheel for a steel one and put a new clutch in and change the cam.
what’s involved with a retro fit roller in a gen I sbc?
I defo think I’m going solid roller.
I had a Comp cams roller cam fail because of the soft metal and their hardening. So I only use billet steel custom cams. So I looked at off the self Comp cams cam cards where it lists all the valve timing events. Let's just say that you look up the https://www.compcams.com/xtreme-ener...all-block.html
Then you go to the lobe chart PDF's and you can see all the availiable lobes from mild to wild. solid roller can handle steep ramps and high valve lifts. I chose endurance racing series lobes with .644/670 lift with my .014 hot lash. Then had it ground on 112 lc. 110 lc would make it sound roudier. My 427 small block I also went with the 4/7 firing order swap
