Dirty Dingo - Sliding or Regular LS Engine Mount Adapter?
Old Jun 24, 2024 | 11:44 AM
rabinaba's Avatar
rabinaba
Default Dirty Dingo - Sliding or Regular LS Engine Mount Adapter?
The time has come! The engine and trans are finally going into my ‘81.
Well, actually, the body is off, so they’re really just going on the frame. I have an LS1 and T56 that I’ll be mounting using the G-Force crossmember. I’m debating between the regular Dirty Dingo LS engine mount adapter or their sliding /adjustable adapters. I like the idea of the sliding adapters, as I feel like it’ll give me more freedom to place the engine where needed - but the adapter sits the engine about a 1/4” higher than typical adapters, and I’m unsure if that will result in any clearance or driveline issues.
Thoughts? Is it worth getting the adjustable ones or should I stick with just the regular engine mount adapter?
Old Jun 24, 2024 | 04:34 PM
71 Vert LS1's Avatar
71 Vert LS1
Can't imagine 1/4" engine height wise will make a difference. The slider type seems like the hot set up for most. On my 71 C3 LS1 swap the intake was not close to the under side of the hood.
Old Jun 24, 2024 | 06:18 PM
Corey_68's Avatar
Corey_68
Depending where you put it ( forward, stock or rearward) will also open up other challenges. I did not want clearance issues so wanted stock location, I felt it was easy to modify the T56 shifter to place it in the original 4speed location.
Old Jun 25, 2024 | 07:22 PM
cagotzmann's Avatar
cagotzmann
This will need to be addressed. or you may get vibration during acceleration at certain RPM's
Angle of the transmission yoke eg. Down 3 degrees
Angle of the diff yoke eg. down 0.7 degrees (this should match the transmission yoke angle)
Angle of the drive shaft. eg. 0 degrees (this would give you a 3 degree angle for the u-joint)
Ideal would be transmission yoke 3 degrees, diff yoke up 3 degrees, drive shaft 0 degrees. angles are parallel. Factory C3 corvette is the w config. (engine down, diff down)
So to adjust this requires engine height adjustment, transmission height adjustment, diff adjustment.
The more adjustment choices you have the better.
Old Jun 25, 2024 | 10:04 PM
carriljc's Avatar
carriljc
rabinaba
I found fellow's video because I was looking for views of tranny exhaust pass under crossmembers. Take a look at that mounts he uses at 40 seconds into the video and see if that would work for you.
I believe it is this kit: https://www.brphotrods.com/p/LSX23/6...rsion-kit.html
To Dirty Dingo - Sliding or Regular LS Engine Mount Adapter?
