Wrong tires
Old Jun 24, 2024 | 04:17 PM
tankgirl's Avatar
tankgirl
1st Gear
Default Wrong tires
Bought 1981 used. Had bigger tires on the back, although tires SHOULD HAVE been the same size. Whoops previous owner.
Switched back to stock tires, but there's something off- it CLUNKS.
Jacking it up...
Where should I look first?
Old Jun 24, 2024 | 04:29 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Well, at everything. You could get more in detail about the clunk. Like when does it clunk, etc. But there are a few things to look for under there. Probably start with the U joints.
Old Jun 24, 2024 | 04:30 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Did it clunk with the old tires on? When is the clunk heard? Remember, with the car jacked up you shouldn't spin the wheels as the half-shaft angle is too acute.
Old Jun 24, 2024 | 05:00 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
They don't necessarily need to be all the same size - who told you that!
What exactly does bigger mean? Taller/Wider/Both?
What size was on there before?
Old Jun 24, 2024 | 05:47 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
It could need a fluid change in the differential with the proper GM posi additive
Old Jun 24, 2024 | 06:05 PM
MelWff's Avatar
MelWff
Jacking it up...
If it's an automatic and it clunks going into gear, the rubber pinion snubber bushings are worn.
Old Jun 24, 2024 | 07:05 PM
Bikespace's Avatar
Bikespace
What size is "stock"?
I'd suspect that something other than tires is the issue.
Old Jun 24, 2024 | 07:33 PM
gjohnson's Avatar
gjohnson
Tire size is personal preference,
To Wrong tires
